Results 1 to 3 of 3
    western Colorado
    Default After 2015 RTS cable lube procedures and what zerks?
    Anyone know what the procedures are for lubricating the cables. Also what type of grease and zerk type hardware is used on suspension components.I picked up the can am xps cable lubricant. I see fittings on both front suspension but can’t seem to find anymore info. Most stuff is generally oil/ coolant maintenance.
    Durham,Maine
    If you have Zerks there should be on each of you bushings on your swing arms, they dropped them a few years ago I believe, they want you to wear them out so you can replace them! Cable lube, they have a neat tool that hooks on you cable end and you shoot the lube up the line and not make such a mess, I got one at a bike shop, works great!!
    2012 RTL , Pearl
    western Colorado
    I’ll look into bike shop. What cables did you lube?
