Results 1 to 14 of 14
    Jun 2018
    Mn
    Post I need handlebar risers
    For 2008 gs sm5
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by Edmunq1337 View Post
    For 2008 gs sm5
    Here you go. Little pricey but well made/
    https://rivcoproducts.com/shop/can-a...and-gs-models/
    Or buy some 4" dog bone risers and make you own. That is the route I took.
    https://www.ebay.com/itm/NOS-1970s-D...QAAOSwj0NUgK8g
    If you need any info on building them yourself give me a hollow and I might can give something to help you do it.
    David
    Aug 2012
    CO
    Default To the OP
    What kind of riser do you need/want?
    Cut or no-cut? No cut blocks give you 1"-2" rise without cutting your bars to pieces, and can re-use your stock control cables. Cut ones require you to permanently cut your handlebars and *may* require longer cables.
    How much rise and / or how much reach back do you need?
    If you can find them used, Heli-bar risers are no-cut and give you 2" up and 4" back.
    Can Am riser blocks are still available if you only need a little rise.
    https://www.ebay.com/bhp/can-am-spyder-riser
    JLohPhotos
    2008 GS , Millennium Yellow
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by asp125 View Post
    I ended up using a block along with the dog bone risers.
    David
    Aug 2012
    CO
    We used the Helibar option. I can't recall if I also used a riser block. I'll have to check the spare parts bin.
    JLohPhotos
    May 2017
    B.C.
    Quote Originally Posted by Warlock View Post
    David
    I used these, no cable issues, there was enough slack.
    Incredible riding difference on my 2012 RS-S, arms and neck are thanking me.
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    I used Helibar 5" risers on my 2009 RS. Don't know if they still make them but I loved the diff. they made. Had enough cable to go 5" up and 2" back. You can see how I sat if you go to my website.
    Ride in comfort,
    John
    Jun 2018
    Mn
    What are easyest 3-4”risers to install cost is not an issue
    Oct 2011
    Magnolia, Ms
    The Rivco ones. Not bad to put on at all.
    David
    Jun 2018
    Mn
    David
    Ordered
    Linden, CA
    Default I have them IN STOCK
    I have what you want just call me, 209-887-3283
    Ride Safe
    Dave
    Jun 2018
    Mn
    Ride Safe
    Dave
    I already odered some. Ya got any seats with front rider back reat for 2008 gs?.
    Jul 2019
    Olympia, WA
    Evening.
    I am looking for a no-cut riser for 2012 RS S SE5
    Are they still available?
    Member BascomWD's Avatar
    Sep 2019
    FL
    Looking for no cut riser for 08 GS SM5
    2008 GS SM5 , Silver/Black
