I may have the most miles on a 1330 ACE engine on my 2014 RT-S. Today mine turned 170,000 miles. Not one engine problem. I have noticed at idle it is quieter than when new. I think with good oil unlimited miles can be had. It still uses no oil
While here I may add the 170,000 mile report. Last year and this one have been expensive. Last summer it was both sprockets and another belt (the second belt). Then both radiators at $300 apiece. This summer my RT started running terrible, only running on 2 cylinders. It was coil packs and I replaced all 3. I also had to replace both front brake rotors. I bought them from Bajaron. I bought the rear rotor last year. Ron says you'll get 20% more stopping power, and I believe him.
I think my RT is running better than ever. Like all high mileage vehicles these things can be expected. But this engine....remarkable.
CHuck
I have "Goldwing blood" running in my veins, that engine is just so smooth. With that said I have an RT with 33,000 miles
and the more miles I put on it the smoother it seems to run. You can do a 500 mile day with no problem. Last summer
rode around Lake Superior, this summer will stay in the barracks until the "oldman" says we can ride again. I'm 70+
and the Spyder is a wonderful machine......
77 here, with 47,000 kms on my ‘14 RTS and still going strong. Plan on several more 1,000 kms before I have to hang it up. Hopefully this Covid-19 won’t put an early end to my riding days.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
Kudos to you guys, 87 here, the Mrs. and I finally discovering the 20 RTL after many years on the GW. Enjoying the change, sure like the GW, and it will probably last for an eternity, but it was a logging truck herky jerky ride, and that's all I'll about that.
Looks like I've got some catching up to do. Mine has a tad over 500 miles, but I just bought it at the end of February. Two things are in my favor though, I'm retiring two weeks from tomorrow.....and the warmer weather is on the way. Stay safe y'all and here's to a bunch of happy/smiling miles!
I have 25,000 miles and going strong!
I have a 2014RTS-SE6.
I did have the D.E.S.S module replaced twice and the keys reprogrammed once( and started a thread about the D.E.S.S errors that I had in 2015, it is a very long thread, with some very helpful info, it has a lot of views, and replies, both times the dess module was covered under warranty).
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
