Results 1 to 25 of 32
    Sebring, FL
    Default High Mileages on the Three Cylinder Engines?
    The title says it all, just curious about the longevity of the Rotax engine. Thanks to those who respond.
    Apr 2011
    GREENVILLE, SC
    Default 100K+
    some on SL have 100,000 miles of smiles and more on theirs....
    i'm knocking on 50K myself... IF properly maintained, these things could run forever in my estimation....
    Dan P
    SPYD3R
    Jul 2015
    Dorr, michigan
    30,000 miles on mine with no problems.
    2020 RT Limited , Petrol Blue
    Mar 2013
    75,000 on our RT. I know others have more. I may think about replacing it (RT) after 200,000 miles.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    34000 on my 2014 RTS with no problems and 0ver 27000 on
    my 2016 F3T with no problems.
    Toby
    2020 RTL
    I think that BuckeyeChuck had well over 150,000 miles on his.
    Jun 2010
    Las Vegas
    Sold my 14 with 123,000 miles last year and its still going strong.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sebring, FL
    I'm impressed, next I look for those who do the long rides, how long, etc, but that's for another thread. Thanks riders.
    The OP asked about the three cylinders.
    I think Ann is the current "champ" on that one.
    The mention of 150K miles on some--I think--were on the 998 two cylinders.
    I have 30K on both my 1330 and 998. Both are going strong.
    Up until now--I have not been a "high mileage" on one type of person. Traded them every other year or so until 2014. Now, I am in the keep-em mode.
    Bottom line--the Rotax is a good engine as well as the ACE 1330. We do not hear of many actual engine failures.
    Chuck did his mileage with a triple: it was a 2014 RT-L...
    Although Spyderjockey has put over 120,000 miles on his 2008 GS...
    Sep 2009
    La Valle, WI
    Almost 20,000 on my 2015 RTS. No problems. Great power train.
    2018 F3 Limited , Oxford Blue
    Jul 2017
    Woodbine, Iowa
    I have a 2015 RT which I purchased with 10,200 last July (2017) now just to turn 22,000 miles. No engine problem at all, was getting DESS Key and replace the DRSS Key modular only thing I have had. That is no engine problem. It runs great.
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Correct
    You are correct Bob. I thought of retiring my 2014 RT-S after a mid speed get-off.
    But there have been improvements, in me physically, and my beloved RT, (new rear tire).
    I have been all around motorcycles most of my life and I have never seen such a well made
    engine. 157,458 miles and never any issues with this engine. No valve adjustments, no
    timing chain adjustments, no fiddling with carburetors, just keep good oil in it and ryde!
    200,000 miles just may be the break in ryde....
    2 cents worth.
    Chuck
    Jun 2015
    Zanesville Ohio
    Default Indeed
    Yes, I do ryde the 2014 1330 ACE 2014 RT-S. I do wish I'd have sprung the extra
    $2000 for the "L" model, but I'll settle for this plain ol' "S".
    Chuck
    #4036
    Active Member ekfraz's Avatar
    houston,texas
    Default mileage
    I have been told by motorcycle mechanics that the engine should last for about 2,500 hours before it needed to be rebuild which is probable 150,000 - 200,000 miles.
    May 2017
    Mesa, Arid-Zone-A
    By today's standards, 150-200,000 miles is short lived. A properly maintained engine should last much longer than that. Last year I sold one of my 2002 Goldwings that had 189,000 miles. It was as reliable then as the day it was new. I kept the other 2002 Goldwing which only has 105,000 miles and it too is as reliable as it was when new. Neither bike has ever had anything mechanical done except for regular oil/filter changes. Neither bike EVER needed any oil added between changes. And, keep in mind, they were built 16 years ago. Mechanically, I don't think our 3 cylinder Rotax engines are any less durable than Hondas. The thing that worries me most about our engines longevity is not mechanical, but all the electrical gizmos associated with its operation.
    Semper Fi
    Sebring, FL
    Thanks for that comment, makes me feel pretty good about the Spyder vs GW, since you were a former GW rider that moved over the to the Spyder. If I think I can get 100K miles from a machine, that is comforting.
    Update: 32K and going with my 2014. Would have been more, but the Vulcan got 4K of my miles in the last year.
    Default 1300 spyder SMILES
    40,000 plus ..... and smiles with all those miles ..........Mike
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    I’m 1/2 that at 21,881 miles......and smiles 😊 😊 😊
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    Active Member Charlottes Web's Avatar
    Northeast PA.
    2012 rts 51,000 sold got a F3L
    2014 rts 55,000
    no problem.
    Chris
    Aug 2019
    Metcalfe, ON
    Likewise - We have just switched over to a new 2018 RT from a 2003 Goldwing with > 100,000 miles on it. Goldwings are known for routinely going 300k miles or more so I'm also curious as to whether the Spyder will come close.
    Sebring, FL
    Mark, I'll be following you comments on the GW vs Spyder RT.
    I have 62K+ on mine now in a month and a half shy of five years and it just purrs along. At my age I suspect that my bones may give up before the Spyder but hope both will get me to 200K.
    Rotax engines have always been known for their reliability and longevity. Rotax makes engines for everything from watercraft to aircraft. They tend to be bullet proof.
