Page 1 of 4 1234 LastLast
Results 1 to 25 of 97
    Active Member jbarrett85's Avatar
    Jun 2018
    Alabama
    Default Best Trailer For Hauling Spyder
    Ok so for the $$ what is the best and safest trailer for hauling my spyder if and when I need to. I am currently looking at the Stinger Can Am Spyder Trailer.
    You can see it here: https://www.redlinestands.com/catalo...trailer-p-2653
    I hope it is a good on, because its one im looking at pretty hard. Let me know if there may be a better one for a good price.
    Oh and my tow max is 1600 #s, so im limited to a lightweight trailer.
    Jun 2017
    Rapid City, SD
    Dang, my 6 by 12 Continental Cargo enclosed was $3200.
    HE>I
    2017 RT , Asphalt Grey
    Aug 2012
    CO
    Enclosed > Open. But since you are limited on tow weight, Kendon offers a Spyder trailer. We had two Kendons in the past for our bikes, and they are quality rigs.
    JLohPhotos
    2008 GS , Millennium Yellow
    Active Member pjweimer's Avatar
    Aug 2012
    Pataskala, OH
    Default Depends on your needs
    If storage space requirements when you are not using the trailer that Redline may be just the ticket. We have plenty of space to storage a trailer and bought an Air Ride back in 2012 when we bought our first Spyder.
    http://the-ultimate-trailers.com/can...r-trailer.html
    We use it a couple of times a year and find it to be a perfect performer.
    2014 RT Ltd Silver Platinum Satin, Ultimate Seat, rider and passenger backrests, Vented Windshield, Adjustable Side Wind Deflectors, Chrome Tri Axis Handlebars with GPS Support, Trailer Hitch Kit, RT-622 Trailer Silver Platinum Satin, Stebil Air Horn, BajaRon's Sway Bar, Spyderpops Bumpskid bike and Trailer, R/T grills, SpyderSisters Front Trunk Pockets, SpyderSisters Sunshade, Spyderflaps Mud Flap, many TricLED lights
    2014 Limited , Silver Playinum Satin
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    The stinger looks nice, and has the advantage of folding up when not in use. But it is a steel trailer so rust may eventually be an issue. Since you are very limited in tow weight, you could also look at an aluminum trailer. I picked up an Aluma this year and had some chocks made for it but otherwise it's stock. Weighs about 625 from the factory and can haul lots of other stuff unlike the stinger. Last week I hauled a new zero turn mower home on it, try that with the stinger. They also make a dedicated trike hauler trailer that fits a spyder. For the flat trailer, it should be cheaper than the stinger by about 500 bucks.
    2010 RT SE5 , Black
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Default Aluma 638
    I purchased an Aluma 638 trailer this year. I made wheel chocks that I drive onto to lift fruck over the frontg of the trailer bed and gives clearance to not bounce on it. It is 63 inches by 8 foot bed. It weighs 390 and cost a little over $1600 with spare tire. I pull it with my Ford Edge and you hardly know its back there.20180609_112940.jpg20180609_112946.jpg20180609_112957.jpg
    2014 RT SE6
    Iron Horse...
    VERY expensive; but worth every penny!
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    I have a 6’ x 10’ Utility trailer with a 4’ bifold ramp. Works great. Only $1500.
    2022 Spyder RT Limited Sea to Sky Mystery Blue
    Active Member ChicoFowler's Avatar
    Omaha, NE
    I got a Bear Track all aluminum 65" x 120" - about 400 pounds. I have a 4 cyl car and needed something a light trailor. The Stinger is a good alternative, but without modification, you can only haul a Spyder. The Bear Track has a bi-fold gate, but with a lighted bump skid on my bike, I had to make ramps in order NOT to crush the skid getting on. Got a 2 x 12 x 8, set of ramp plates for about $50 and I'm in business. Cost for me was reasonable - they run new from 2100 to 2800, depending on dealer.
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    Beware of the Stinger trailer. A friend of a friend bought one and after 6 months rust was showing all over the trailer.
    On his first short trip with the trailer (just to test it out) 3 of the main bolts on the trailer sheared off so he had to leave the trailer to go home and get necessary things to get it home.
    He ended up returning it to the dealer but not sure how he made out money wise.
    I ended up with a Triton AUT 1064. Towed the spyder to florida and back to canada. 2800 miles total. Worked great.
    here's a pic.
    Greg
    2015 RT Limited (White)
    Active Member mhoecker's Avatar
    May 2012
    Springfield, VA
    When we picked up our Spyder we also bought a Triton AUT trailer. Wanted to be able to trailer the bike with the CR-V with a towing capacity of around #1500. This is close and tracks beautifully. Quality built although you have to be mindful of scraping the underside when loading, depending on the angle of the ramp. Our dealer got a couple of boards for us that takes care of everything.
    2018 RT Limited Champagne Dark
    Jul 2017
    Quote Originally Posted by mhoecker View Post
    The first time I went to load the Spyder onto the trailer the front scraped.
    Since then, before loading I use the jack to raise the front of the trailer whil still attached to the hitch on the vehicle.
    No more scraping at all.
    Just remember to let the front of the trailer back down before driving away
    Greg
    Oct 2017
    Portsmouth VA
    Quote Originally Posted by Wrongway View Post
    I ran into that same problem with the aluma trailer. On the camper, I got an adjustable height hitch and raised the front up about 3 inches, on the car, I can use the jack to boost it up. On the dedicated MC trailers, I think the ramp is a bit longer, but there are easy ways to get around the scraping.
    2010 RT SE5 , Black
    May 2013
    Indiana
    Iron Horse...
    Sometimes they get used ones in on trade that are a pretty good deal. They only have enclosed trailers for spyders:
    a. 2-bike/1-trike trailer, and
    b. Widebody
    Give them a call and talk with them about what works for you.
    Mike
    2021 Marsala Red Metallic RT Limited
    Mike,
    I just realized something:
    Once Tom & Ali set up camp in Florida: we'll have a place to stay down there!!
    I've got to remind him to put a 30 amp RV service out near his driveway!
    Jun 2018
    Alabama
    Talking
    Thank you all for your replies. I will definitely look into other trailers. The last thing I need is the trailer breaking down on me.
    May 2011
    Ocala, Florida
    Default Drop Tail Trailer
    I bought one of these in 2014 and have used it a lot. I put the optional stone guard on the front. Trailer weights about 600 lbs. Solid deck so it can be used to haul other things. Also folds up and stands up for storage if space is a problem. Good quality. No problems. A bit pricey but very versatile.
    Sep 2015
    Parkesburg,Pa
    Quote Originally Posted by SpyderJerry View Post
    Now thats a perfect fit,will have to look into one of those.
    Active Member Jarred's Avatar
    Jul 2018
    Long Island NY
    Default Trailer
    I’m in the market for a trailer as well. I filled out that form from Ultimate Trailer to get a quote from them, can’t wait to hear the price........
    so right now, I’m leaning towards the Stinger. Great for storing when not being used and they have great reviews. I have 2 kids, so trailering the Spyder to Lage George or VA Beach sounds like a lot of fun.
    ‘Keep us in the loop, good luck!
    2018 RT Limited Metalic Champagne
    US Spyder Ryders Long Island NY Chapter
    2018 RT Limited , Metallic Champagne
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Default ultimate trailer
    Quote Originally Posted by Jarred View Post
    I got a quote from them. It was just about six grand for a loaded open trailer. It looks like a great trailer, but that's pretty steep in my opinion.
    Jul 2018
    Long Island NY
    Default WOW! $6k??
    Thanks for letting me know price on Ultimate Trailer. It’s very nice but not only expensive, also takes up a lot of room when not using. I already have my empty boat trailer in driveway (boat in slip).
    ‘So now I’m pretty sure I’ll buy the Stinger. Looks good, great reviews and easy storage/free shipping.
    ‘Thank you!
    Jul 2008
    Mesa AZ
    Default +1 for the Aluma 638
    This is the same trailer I hauled my 09 GS on for many miles. I tows like a dream. Give it a good long look!
    It also hauls a golf cart perfectly.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Lamar 6X10
    You have a lot of answers, but here is one more: I have a Lamar 6X10 with custom made front chocks and E-Track (loop around the rear tire) for anchoring the rear tire. I did over 3K miles to/from South Dakota from Tucson. Didn't move a fraction of an inch and didn't have to tighten anything even once. Heavy duty with 15" tires and spare. High quality unit.
    I wish I had realized the Aluma 638 would work as I would have seriously looked at it.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Jun 2018
    Alabama
    Thank You all for your replies, I ended up going with the aluma trailer. So far I love it, and it pulls like a dream.
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    Quote Originally Posted by jbarrett85 View Post
    Good Choice! Those trailers are made just 20 miles from my house and they are very well built. I don't have the spyder anymore but I still have my trailer and I use it quite often. If i ever get another spyder, I'll be set!
    I have the 7710 with the front rock guard and the bi-fold rear ramp. The bi-fold is a little longer so it helps with the nose clearance.
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
