Results 1 to 25 of 33
    Active Member Air Force PAO's Avatar
    Jul 2011
    Kyle, TX
    Default RT622 Wheel Bearings
    Howdy, y'all,
    I have limited time this Saturday to inspect my RT622 wheel bearings and replace them if necessary.
    So...what size socket do I use to remove the wheels? If I need to replace the bearings, can I find them at Autozone?
    Thanks in advance.
    John
    Test message.
    2016 Spyder RT
    Sep 2014
    USA
    https://www.ebay.com/itm/K1-150-2-00...l/111709525286
    Remove cup,remove cotter pin,pliers or crescent wrench will get the nut off.
    Bryant, Arkansas
    Be sure to check both (front & Rear) sets of bearings on both wheels
    Cruzr Joe
    SoFlo
    Cruzr Joe
    Agree.
    Be prepared to clean the axles also, not only of grease, but possible light corrosion. Use maroon Scotchbrite pad for that.
    I cleaned and repacked our RT622 bearings recently. Installed Bearing Buddies. Some here are not fans of Bearing Buddies, but done correctly, they work well.
    INDIANA, USA
    Default Bearings
    Just a TIP, You should check all bearings. If you find a 'Bad Bearing/Race' replace everything for that wheel. I would recommend doing both wheels....
    ENJOY YOUR LIFE WITH A SPYDER
    Mar 2013
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jun 2010
    Las Vegas
    Quote Originally Posted by Little Blue View Post
    Or just replace the entire hub, a fairly inexpensive item in the world of Spyders.
    I would not count on Autozone having replacement bearings, you need a bearing supply store.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2011
    Kyle, TX
    Thank you all. This is great information.
    John
    Test message.
    2016 Spyder RT
    Sep 2014
    USA
    The hub is around 80 bucks if my memory is correct.
    Dont forget the seals.
    Let us know if you see rust on and around the axle.
    SoFlo
    Wanted to add, a short while back I helped another local rider replace the bearings on his RT622 trailer.
    The design of the hub was machined so there was no lip to catch and drive tne bearing cup out of the hub. The crew hear gave a slew of methods. Anything from run and electric welded bead around the race to the guy was clueless and they come right out. To remove the cups, I had to use a carbide rotary file spun by a die grinder, and created notches that allowed the punch to seat and the bearing cup was driven out.
    Mentioning this to let you be aware of possible extra tasks to accomplish a simple task.
    Sep 2014
    USA
    I managed to get mine cups out with a chisel/punch. I know the angle made it almost impossible to remove that way but I did it get it done.
    Got lucky not having to use a grinder
    SoFlo
    Simply, you were lucky to have an exposed edge of the bearing cup to work with. The hubs I dealt with, the hubs casted bore was a smaller diameter than the bearing cup. There was no lip exposed to catch any tool of any type. Without cutting material away, the hubs were one time use.
    Pretty much one of the stupidest hub / bearing designs I have ever seen.
    Mar 2013
    Simply, you were lucky to have an exposed edge of the besting cup to work with. The hubs I dealt with, the hubs casted bore was a smaller diameter than the bearing cup. There was no lip exposed to catch any tool of any type. Without cutting material away, the hubs were one time use.
    The two times I have done the races I used a blind hole puller with a 5 pound slide hammer. This worked great!
    SoFlo
    Quote Originally Posted by PW2013STL View Post
    Again, you were simply fortunate there was a means to grab the exposed lip of the bearing cup. These hubs I worked on had no such means. As I stated, the hubs inner diameter was a smaller diameter than the actual bearing cup.
    A blind bearing puller would have been great also, but with no ledge to grab, this would have required cutting away even more of the hubs material than just a few notches.
    The fortunate thing though, these hubs are pretty soft cast steel, so the carbide cutter made easy work of it.
    The original post here, if he needs to replace bearing cups, possibly he is fortunate as others are, or may be in deep doodoo if like the hubs I helped with.
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    All this talk about hub quality begs the question.
    Did we get what we paid for?
    SoFlo
    Quote Originally Posted by Jeriatric View Post
    Absolutely. The RT622 is a great trailer that matches the style of the Spyder RT series.
    Regarding these wheel hubs, they are no better, nor any worse than those on the Spyder itself at the price point they meet.
    Actually, current automotive trends are leaning more and more to replacing complete assemblies. I am planning to accomplish wheel bearings in my Toyota Tacoma, and by design, everything is pressed together, and the bearing is a complete assembly consisting of inner and outer bearings.
    Apr 2012
    Agree
    Sep 2014
    USA
    Yes. I was lucky. Didn't have much to work with until it started to move.
    I was hoping to find a aftermarket replacement but could not come up with one that the specs the 622 hub had.
    Jan 2018
    mondovi wi
    if you do not have a maintainance book for your RT622 the book shows that the wheel hubs & sealed bearing is a complete set ..bearings were not intended to be pressed out and replaced. I see someone had stated about the soft hub metal. it is , canam had no intension to just replacing the wheel bearings. yes these are intended to be replaced just like your truck and or car wheel bearings ar built the same way..
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    I started to pull one of the RT622 wheel hubs apart today. The cotter pin, nut, washer and outer bearing came out easy. It seems that the inner bearing is hanging on the axle so I cannot pull the hub. Do I need a wheel puller to get the hub off or just use a rubber mallet and smash it off?
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Jul 2010
    Las Vegas, NV
    Bob, that’s the oil seal hanging up. Just tug. You gotta replace it anyway. Once the hub is off, use a Dremel tool On the race and cut in a groove. Use a hammer and chisel to remove. You can cut on each side, and remove that way. I used a drill to make a hole, and then put a punch in that, once. Again, worst case, beat it mercilessly, ruin it, and then pitch it! New ones are pretty cheap. Bearings and races and seals are available from bearing supply houses. 14848 CR seal and L44649 Timken bearing and races. Call if you need help.
    Joe Meyer
    Mar 2010
    Derry, NH
    Thanks for the info. I spent some time in the garage earlier today and got the hubs off using a rubber mallet. One of the bearings is still on the axle, I was surprised that it separated from the hub so easily. A rubber seal (rear) came out of the other hub. The grease in both hubs looked like wet mud, tan in color. I didn't expect the grease to look like that. I am really glad I took the time to check the bearings. I have low mileage on the trailer and assumed they would be fine.
    What type of grease should I use?
    Bob H - Derry, NH
    Sep 2014
    USA
    I used Synthetic bearing grease and installed bearing buddy. I have not taken them apart yet to see how well the bearing Buddy has worked out.
    Take a close look at the trailer axles for rust more so the back side. If not cleaned up it will destroy a seal.
    Jul 2010
    Las Vegas, NV
    Synthetic grease is fine. We also use bearing buddies
    Joe Meyer
    Mar 2010
    Derry, NH
    Joe, I sent you a picture via email. I had a bit of scoring on the axle when I removed the inner bearing.
    Bob H - Derry, NH
