Results 1 to 11 of 11
    Invalid Emails
    Oct 2014
    Calgary, Canada
    Default Headlight adjustment
    I have installed LED headlights and they seem to be pointed a little "tall" and I would like to point them down about 1" or so when pointed at my garage door from about 6'.
    I read somewhere that to adjust them you "rotate" them one way or the other and that would do it. I have no idea if that is true ...
    Just how does one go about adjusting their headlights on a 2014 RTL?
    Look at pg 136-137 of your operator's guide.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by blitzkreig View Post
    I have installed LED headlights and they seem to be pointed a little "tall" and I would like to point them down about 1" or so when pointed at my garage door from about 6'. I read somewhere that to adjust them you "rotate" them one way or the other and that would do it. I have no idea if that is true ...Just how does one go about adjusting their headlights on a 2014 RTL?
    Each headlight has a enclosed cable that terminates in a knurled knob at the side access panels. That is what you 'turn' to adjust the height of the headlight, not the headlight itself.
    2014 RTL Platinum
    Danbury Connecticut
    If you remove the access cover on either side you'll find the adjusting cable shown as "1" below. Loosen the locking nut and twist the cable in one direction or the other until the headlight is pointed where you want it to go.
    Remember, the headlights will change point, depending on how heavy you load the motorcycle.
    I hope this is helpful
    IBA #47122
    2020 RT Limited Asphalt Grey
    Dec 2015
    Oakley Utah
    If you remove the access cover on either side you'll find the adjusting cable shown as "1" below. Loosen the locking nut and twist the cable in one direction or the other until the headlight is pointed where you want it to go. Remember, the headlights will change point, depending on how heavy you load the motorcycle. I hope this is helpful
    ThreeWheels, thanks for the pic. As I recall, though, the locking nut is to hold the cable in place. I don't think it needs to be loosened in order to adjust the headlights, but I could be wrong.
    2014 RTL Platinum
    Invalid Emails
    Oct 2014
    Calgary, Canada
    Helpful? ... WOW.
    The instructions on the LED package had me in there twisting the bulb in the housing. This (if it works ... and I'm sure it will) it is sure be a LOT simpler to do than what they had in mind.
    I am about to leave on a trip in which we will be loaded down quite a bit and I am sure it would be aiming my headlights over where they should be.
    Thank You!!!
    Dec 2015
    Oakley Utah
    Helpful? ... WOW. The instructions on the LED package had me in there twisting the bulb in the housing. This (if it works ... and I'm sure it will) it is sure be a LOT simpler to do than what they had in mind. I am about to leave on a trip in which we will be loaded down quite a bit and I am sure it would be aiming my headlights over where they should be. Thank You!!!
    That's what your remote level adjuster is for - to let you level it out for an increased load. I know they say 'soft' and 'hard', but it's really load leveling.
    2014 RTL Platinum
    Invalid Emails
    Oct 2014
    Calgary, Canada
    Now that makes sense too. I never could quite get the "soft and hard" bit as it never seemed to change much for me ...
    May 2013
    Edmonton Alberta, Canada
    You are correct, the nut does not need to be loosened to adjust the headlight.
    2014 RT-Ltd , Cognac
    Nov 2018
    Claremore, Ok.
    Before you go adjusting headlights after installing LEDs, check to see if the HI beam and Lo beam is still hi and lo. A lot of LEDs have come with the leads reversed. If so, switch the leads in the bulb socket.
    May 2017
    Mesa, Arid-Zone-A
    You should be able to just adjust the rear shock to keep your headlights in proper adjustment when you load the bike. That is if they are properly adjusted before you load the bike up. Check it out on the garage door. See the top of the light edge. Then apply your load and find where you need to adjust the suspension to have the same measurement. Easy.....
    Semper Fi
