Results 1 to 18 of 18
    Feb 2018
    Queensland Australia
    Default Finally found time to install my fuel door!
    Finally found time to install a fuel door. For those who may be confused as to what door to install, this door is for a 94-99 GMC Yukon/ 99-00 Yukon-Denali-escalade. The outer ring diameter is 6 3/8''. I've have big hands & have no problem getting my hands through the door to the gas cap. I installed a PermaCap11 which makes it's easier again.
    A special thanks to BLUEKNIGHT 911 for his invaluable info, & made it a piece of cake to install the door. Thanks again Mike.
    Default Well done....
    Even with the help of our resident expert on gas doors...still a good job. Looks great in black and handy no doubt...
    ​2012 RS sm5
    Feb 2018
    Thanks Chupaca, & yes It's very handy.
    Feb 2018
    , Thanks for the shout -out .....and glad I could help .....You did a nice job on that install ...........Mike
    Thanks Mike.
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default Expert installer
    Looks nice - now you are the latest expert installer. I'll need to make a trip to Australia so you can install one for me. *lol*
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    A good job.
    Jun 2017
    FL
    Do you have a part number? Also, how did you install it and what kinds of tips do you have? My wife has a 2016 Rt Limtied and we need to install one now that my wife is traveling with her terrier in a pet holder on the back seat. Thanks!
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Gregtal View Post
    I agree. It's time for me to consider doing this mod on our two bikes so I don't have to lift up the seat (and remove whatever is on it) each time I refuel.
    2014 RTL Platinum
    Jun 2017
    FL
    Another question - is there an inner ring part that the door locks onto? I found the fuel door on ebay, but it appears to need an inner ring because the lock flange on the picture of the part they posted doesn't mesh with anything...thanks!
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    I do not think this will work on the F3.
    2017 F3, SM6-basic black, plain and simple
    I sent you a PM about this ….. Mike
    Feb 2018
    Looks like BLUEKNIGHT911 has sent you his really good info. There is no inner ring. When the door is shut & the key turned to lock the door, the flange uses the thick plastic seat material to lock behind. See post #1 for the door. Manufacturer part # CBK-101BK. I've attached a few photos. Once the door is mounted, I filled in the void with black silastic. To Smooth it off use some watered down detergent or spit on your finger. See photo 3. Fairly easy job, & don't rush it.
    Quote Originally Posted by treva View Post
    and I see Treva used " T " nuts on the inside ...……...Mike
    Dec 2016
    Gold Coast, Australia
    G'day Treva
    Where in Queensland are you located. If close to the Gold Coast, I would not mind having a look if that is OK with you.
    Cheers
    Frank
    Dec 2015
    Oakley Utah
    Does it matter where the hinge is located?
    2014 RTL Platinum
    Feb 2018
    Quote Originally Posted by Fearless View Post
    G'day Treva
    Cheers
    Frank
    Hello Frank, I'm located at Montville [ Near Maleny ] Sunshine Coast hinterland. If your up for it, by all means do come & have a look. Better still, ride up, or take seat off & drive, & I'll fit the door. No charge. Just Good to meet like minded spyder riders. Treva.
    Feb 2018
    G'day UP, yes it probably does matter. I installed the hinge for the door to open from left to right so it wouldn't interfere with the bowser fuel handle. It works a treat, & should be fitted as standard. Treva.
