All 2013-up with Brembo brakes (Parking brake arm bolt check) WARNING
Two days ago while out for a ride, the bracket that bolts on to the rear brake caliper and that the brake cable hooks on to fell off my bike. I did not notice this till I got home and tried to set the parking brake. Somehow the bolt must have vibrated loose. The problem, BRP does not offer the bracket seperately. But you can buy the spring and bolt which holds the arm onto the caliper. Make sure the bolt is good and tight when ever you have brakes serviced.
BRP should make this available. Why force us to buy a whole new exspensive caliper assembly, when all we need is the Arm, Spring, & Bolt - probably less than $60.00. We've already spent enough for the bike.
Attached Below is the picture of the Bracket in question. It's bolted to the caliper with spring attached at the bottom cable hooked at the top. Make sure this bolt is tight each time you have brakes done.
Reason: Fixed attach display
Attached Below is the picture of the Bracket in question. It's bolted to the caliper with spring attached at the bottom cable hooked at the top. Make sure this bolt is tight each time you have brakes done.....
Try this part number 219800241. It says that it is CAN-AM - CABLE SUPPORT/LEVER FOR REAR
http://www.2wheelpros.com/oem-parts/...0241-part.html Just over $30
Reason: Fixed quote display
Thanks... I'll be checking mine before I hit the road again.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Not the correct bracket
Originally Posted by Fatcycledaddy
According to my dealer the bracket in that kit is not the correct one I need. Waiting to hear back from BRP as to which kit has the bracket I need.
Pictture added
I made you one.
Here ya go. Fits and functions perfect.
Originally Posted by Joel The Biker
Thank you Joel.
Over the years we've made great friends through this forum. Today is a perfect example of the Spyder community coming together to solve problems.
Thanks Jose. I am always willing to help out my friends. It was kinda fun to make. I guess I was a little bored this morning.
Attaboy Joel! I took mine off today, cleaned up the threads and put a dab of loc tite on it.
Sena 20s
Joel, that was great thing you did there. My hat is off to you. Bruce
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
Joel, you should be working for BRP. At the very least, they should hire you to improve their customer service. Your an "A+" guy.
Parking brake Arm
Joel, thanks once again, got the bracket you made today It's installed and working perfectly.
SpyderLovers Sponsor
Very cool!
Sweet! That's why this forum rocks! Nice job, Joel!
Joe Meyer
Wow - nice job
You are great Joel and very talented - what a nice thing to do.
What did you use to make it, a plasma cutter or water jet cutter, or something else of the sort? I was wondering how you duplicated the shape. Make a digitized copy and load the CNC or is there some way to trace the original shape? I'm just curious. I guess it's my engineer nature.
I made it by hand with hand tools. Sawsall, grinder, drill, files, and a sander. Took about an hour.
You the man .
Klinger's?
Are you going to Klinger's in Walton?
No
I will be in Rosendale, NY.
Craftsman in action!
What a joy to see that hand craftsmanship is alive and well! Great job, Joel!
Nevet would have knowm
You have to see it to really appreciate the workmanship. I will keeping this as a spare just in case.
I would have made it a little prettier, but had to get it to the post office before it closed. Function over style I guess. I think the paint was still drying when I mailed it!
Hi,
I'm hoping you can help me with the part number for the spring and bolt. I just noticed that my bolt isn't there and i cant find the part number. I still have the spring but I'll be happy to buy both if that's how they come.
