Results 1 to 9 of 9
Thread: Rear axle tool
    Mar 2018
    Brownsboro TX
    Default Rear axle tool
    Greetings all,
    can someone point me to me to where I can buy the special socket to remove the bearings from the rear wheel of a 2013 can Spyder ST
    Various bikes since 8 years old
    1999 Honda Nighthawk
    1999 Honda Pacifica
    2005 BMW 1150 RT
    2007 Yamaha Roadliner
    2007 Yamaha Royal Star Midnight Venture
    2013 Can Am Spyder ST
    Aug 2013
    SF Bay Area
    I believe this is what you’re looking for. Park Tool Freewheel Remover: BMX One Color, One Size https://www.amazon.com/dp/B000NOO4PK..._yhflBbXQZ5VMM
    when I did mine I was told it should be done when you replace the tire. I found my original bearings to be fine and didn’t plan on replaceing them next time. It’s not easy.
    2021 F3 Ltd , Magna Red
    Mar 2018
    Brownsboro TX
    Default Thanks
    Are you fairly sure this is the correct size? I have already changed the bearings. I had to Fabricate a tool to get that odd nut off. I just thought I would have the correct tool next time.
    1999 Honda Pacifica
    2005 BMW 1150 RT
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    That's the one that's been recommended.
    I bought it recently in anticipation of doing this job at my next tire change, but haven't personally tried it. So if you also take a leap of faith and buy it, let us know if it does or doesn't work.
    2020 RTL SE6
    Feb 2015
    Carson City, NV
    Default Tool
    I used a piece of flat steel about 3 inches long and a crescent wrench, but I saw where someone welded a large nut to a piece of flat steel. Seems like it's always something weird on this bike. I had a VERY hard time getting the inside bearing out......and of course, nobody stocked all 3 bearings, so better order them ahead of time. Or go to a different manufacturer. Good luck.
    Bob, k7xi. 2013 RTL
    Jul 2010
    Las Vegas, NV
    Default Wheel bearing tool
    Wrecking bar, Home Depot, 20 bucks. Fits perfectly, works great!! I have several. The special tool was crazy expensive for how often I would use it. Turns out, never!!
    Joe Meyer
    Mar 2013
    Quote Originally Posted by k7xi View Post
    Like this?
    Works great and I can use a torque wrench with it!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2013
    Houston
    The correct tool shows up on ebay for under $20 fairly often. Thats where I got mine.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    The best substitute for brains & knowledge is....................silence.
