Results 1 to 20 of 20
Thread: Tire Question
    Oct 2013
    Wood Village OR
    Default Tire Question
    I have tried searching the tire threads till my eyes crossed. I am looking for the size I need for the Vredestein Quatrac that will fit my 2014 RTL for the front.
    2014 RTL , Black Currant
    May 2017
    Mesa, Arid-Zone-A
    Try 175/55R15. Little bigger than OEM but fit fine. That's the size I am running. When I pulled the old tires off I was concerned about the fender bolts rubbing the inside of the wider new tires. Don't know if they would but to be cautious I pulled each fastener out one by one and snipped about a quarter inch off each one with a bolt cutter. Takes only a couple minutes per side. Then took old tires and wheels along with new tires to Costco and had them mounted & filled with nitrogen.
    Semper Fi
    May 2017
    Mesa, Arid-Zone-A
    Actually it is only slightly wider ...... the OEM 's are 65 Aspect ( sidewall ) the 55 is a bit smaller so it should not be a problem .................. Mike
    Thanks, Mike. I didn't think there would be any problem but those extra long fender bolts just looked menacing. So, I gave them a snip job. Easy to get out and easy to get back in. Menacing no more.....
    Semper Fi
    Oct 2017
    N.E. Ohio, USA
    Quote Originally Posted by easysuper View Post
    I have 165/65/14 Quatracs coming from Tire Rack today. $160.18 to my door. Two fronts.
    Ride safe!
    2018 Spyder RT Limited
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default ...are you sure?
    Quote Originally Posted by daz View Post
    I havre 165/65/14 Quatracs coming from Tire Rack today. $160.18 to my door. Two fronts.
    ... you are saying your 2014 RT is running on 14" rims ? I am under pretty sure that in2014 they are on 15" rims.
    If I am wrong, please correct me..
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by Richardv View Post
    Nope, you're correct.
    2020 RTL SE6
    If I'm understanding what you just posted...
    The tires on the older (pre-2013) bikes were 165/65-14
    The newer bikes use 165/55-15 tire.
    The difference is that they used to use 14" front wheels. They switched to 15" hoops, to make room for the Brembo brakes up front. In order to keep the same front tire width: they just went with a lower aspect ratio...
    No problem, Bro: I had you back!
    Oct 2013
    Wood Village OR
    Default AnotherQuestion
    I'm having trouble getting the Vredestein before I leave for Deadwood, My other choices are a Kumho Solus or a Hankook Ventus , what do the tire experts out there say ?
    Oct 2013
    Wood Village OR
    I'd really like to assist on this ....However most of the Hankook brand are called " Ventus " ( I guess they like that name ) ....Kumho isn't much better , they also like " Solus " name ...... So more info is necessary ........ Too bad on the Vredestein they are lots better than the other two, by quire a bit ....... Mike
    The two that I was looking at Mike were the Hankook Ventus V4Es H 105, in a 175/55 R15 SL BSW OE. Or The Kumho Solus KH16 in a 175/55 R15 SL BSW OE.
    I am open to suggestions , I am not a aggressive rider , but we do a lot of touring with a trailer, I have 34K on the factory tires on the front and going on my second Kumho on the rear.
    Oct 2013
    Wood Village OR
    Thanks -...the Kumho only has a good rating for Dry, Wet, and Wear ............ that Ventus also has " good " rating for D,W, & wear ......... it's numbers for good are slightly better than the Kumho but we are talking tenths of a percent ..... VS. the Vredestein Quatrac 5 , which is in the excellent range for 5 category's which includes comfort & winter ..... considering you will have these tire for possibly 35,000 + miles !!!! .......your call ....Mike
    Here's another question Mike. When I try to order these over the phone what car do I tell them I'm putting them on because we all know if I tell them my spyder they will not sell them to me.
    Thanks .
    May 2017
    Mesa, Arid-Zone-A
    Thanks .
    Never had anyone ask about the car they are going on. But, if they insist, just tell them they are for a custom vehicle. Phone sales people really don't care about much except getting your credit card.....
    Semper Fi
    Oct 2013
    Wood Village OR
    Quote Originally Posted by canamjhb View Post
    The reason I asked was because EVERY time I have called Discount tire and ordered tires delivered, they have asked me what car did I want them for.
    Nov 2008
    las vegas, nv
    What sizes are acceptable?
    165x55x15
    175x55x15
    Any other options that did work?
    I have 2015 RS with newer front fender with led lights.
    Thank you.
    6 states down 42 states to go
    Jan 2018
    Australia
    Just thought I'd have a look at wheel-size.com to see what differences between the 175/65R15 and the 55R15s …
    Tires Tire 1 (175/65 R15) Tire 2 (175/55 R15)
    Section Width 175 mm % 175 mm = %
    Sidewall 114 mm % 96 mm ↓ 15%
    Overall Diameter 609 mm % 574 mm ↓ 6%
    Rim Sizes 15x5 15x5.5 15x6 15x6.5 15x5 15x5.5 15x6 15x6.5
    Circumference 1912 mm % 1802 mm ↓ 6%
    Revs per mile 842 % 893 ↑ 6%
    Speedometer Assuming that this is OE tire and speedometer readings are correct % When speedometer reads 60 km/h actual speed will be 56.5 km
    Does this sound like its about right to you guys ?
    Jan 2018
    Australia
    Quote Originally Posted by aka1004 View Post
    165x55x15
    175x55x15
    Thank you.
    AKA … have a squiz at wheel-size.com and there are others out there too …
    The beauty of these is you just dial in (fill in the blanks) your current wheel/tyre and then in the adjacent column dial in the dimensions of the wheel/tyres you are wanting to go to as the modification / adjustment … Straight off it gives you changes in just about anything if there is to be any … And what you need to do to make it work and complete with active diagrams so you can see the changes
    It has been a real eye opener for me in some ways … just such things as one profile size change on average (up or down) will change the tyre width by a whopping 1/2" accordingly … I never knew that !… So when juggling this stuff it will give you concise information on any proposed differences. in just seconds.
    All of this is 'supposed' to be independent of brand. (Apparently all tyres of a specific nomenclature/description supposed are exactly the same size etc as the next brand … Hmmm, I'm not really convinced on that one … but until I see otherwise I'll go along with it! ..)
    with Mike! Those internet sizing charts show the NOMINAL sizes for tires for comparison purposes, but each manufacturer can use different methods to determine which nominal size they want to put on their tires, and the nominal sizes can often be anything up to 20-25mm different to another manufacturers tire with the same label on the sidewall!! And the rolling dia or circumference can be even more different! The biggest variation I've encountered so far was 50mm difference in rolling diameter from the nominal size, but that was an off-road tire.... still, I've got 1/2 dozen different brands of the 'same' nominal sized car tires here right now to write up, and not one brand is the same size as any other, nor are any of them ACTUALLY truely the size as the size printed on their sidewalls - but the internet charts would have you believe they are all identically sized & if you know which method each manufacturer has used to arrive at that particular nominal size, you can see there's an arguable case.... arguable, even if not necessarily quite believable!
    The ONLY way to really compare tire sizes is to compare the physical dimensions of each tire.... the manufacturers do publish them.
    Nov 2008
    las vegas, nv
    thank you and I have used 175 before with old fender without a problem but these new fender seems to have less room inside the tub so I was trying to find which ones, exact brand and size actually fit.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Thanks .
    In they absolutely insist on knowing, try either of these:
    - "These are exact replacements for tires already on my car." (On some menu-driven websites, this is actually an option)
    - "1970 VW dune buggy."
    Slightly OT: I'm starting my search for a new rear tire. I just learned that Walmart carries the General Altimax RT43 line (which I currently have on my Spyder). No more weasel-wording your order with Tirerack! $80.
    Oct 2014
    Kumbo KH16 does fit both fenders style, so does the Hankook v4. Both in the 175/55R 15 size.
    Richard
    1 set of Hankook V4
