Results 1 to 8 of 8
    Active Member MangoMike's Avatar
    Feb 2009
    Tampa, FL
    Default Pairing Scala rider TeamSet Pro
    2018 RTL and older bluetooth Scala TeamSet Pro headset. Headset pairs with iPhone 6S, but I cannot get the headset to pair with the bike. Has anyone successfully paired an older Scala with BPR Connect?
    We used a set of them for years as our intercoms. They were a fine stand-alone item; but we could never get them to pair with anything else!
    Feb 2009
    Tampa, FL
    Thanks Bob. That's been my experience as well, although for years I didn't need to pair them with anything else. Guess I'll have to buy something new, any suggestions?
    Sena: contact MotorcycleDave.
    Tell him what you want to do, and he can set you up!
    Aug 2013
    SF Bay Area
    You can’t be paired to the phone AND the bike. Remove the headset from the phone and then try pairing to the bike. You will be pairing to the phone but through the bike’s system. Make sure all other Bluetooth devices are off (or the BT is off).
    2021 F3 Ltd , Magna Red
    Feb 2009
    Tampa, FL
    I tried this, no luck. Thanks for the suggestion.
    Aug 2013
    SF Bay Area
    I’m hearing that the Schubert helmet is not pairing. Have you updated the firmware on the headset. Also there is a software update for the bike that might help.
    I had had to try several,times and make sure to reset the phones and bike. If it doesn’t pair after half a dozen attempts, all I can think of is it’s time for a new headset.
    Feb 2009
    Tampa, FL
    I've pretty much come to this conclusion, and I hate to spend that much money on something that will get so little use. I'll have to think about this for a while.
