Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
  1. #26
    Feb 2019
    Portland, Oregon
    What year and model Spyder do you have? What was the correct Part Number you ordered?
    I have yet to put Speed Bleeders on my 2017 F3L as I only had it since Feb. and only have 400+ miles on it due to life getting in the way. But I will be ordering (by phone) soon.
  2. #27
    Nov 2018
    Claremore, Ok.
    does anyone have a part # for 2015 RT Speed Bleeder?
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
  3. #28
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Revalden View Post
    It's best to look up their phone number and call in your order, they will send you the correct ones. As I posted above.
  4. #29
    Member DimSum07's Avatar
    Mar 2019
    Annandale VA
    I sent them an email today. Witney replied and I've ordered Speed Bleeders for my F-250, CRV and F3 Limited.
    F3
    Front……SB8125L
    Rear…….SB8125L
    ABS Unit….SB1010S
    -Steve
    2016 F3 Limited
  5. #30
    Mar 2008
    Hesston, PA
    Here is a copy of my order for my 2014 RTS...I have a ISCI hand brake kit...
    Order Summary
    Speed Bleeder Bag & Hose Combo SB9010 Speed Bleeder Bag & Hose Combo
    $6.00 x 1
    $6.00
    SB1010S / 9407, H9407, 9497-2, H9497-2 Speed Bleeder SB1010S SB1010S / 9407, H9407, 9497-2, H9497-2 Speed Bleeder
    $7.00 x 1
    $7.00
    SB6100 / 9417, H9417 Speed Bleeder SB6100 SB6100 / 9417, H9417 Speed Bleeder
    $7.00 x 1
    $7.00
    SB8125L / 9405, H9405, 9422, H9422 Speed Bleeder SB8125L SB8125L / 9405, H9405, 9422, H9422 Speed Bleeder
    $7.00 x 3
    $21.00
  6. #31
    Feb 2019
    Portland, Oregon
    That's a very fair price for the great convenience Speed Bleeders provide. Not to forget to mention the firm pedal and lever they give you.
  7. #32
    Mar 2019
    Annandale VA
    Update
    The SB8125LL does not fit into the F3 banjo bolt where the original bleeder comes out. I've sent in more information about the bolt to settle on what's going on. Now I need my wife to get home so I can have her help me bleed the air out of the line....
    The reality is, I think you only need 1 speed bleeder to bleed these brakes plus one of the abs unit. Everything else I was able to bleed the normal way using one hand on the brake pedal and the other on the wrench.
    I still intend to put speed bleeders on, but for those who want to be smart with their money, you probably don't need them on every fitting on the bike.
    -Steve
    2016 F3 Limited
  8. #33
    Oct 2021
    NH
    Quote Originally Posted by Jeriatric View Post
    How about if you had a bleed bottle with a check valve in it, for under $27.00?
    It's a one person bleed system that works slick as a whistle.
    That sounds like a good idea. I ordered speed bleeders for my 2011 rt, but might make up a set up for other vehicles I have. My 2011 have 8mm bleeders and found 2 pairs on Amazon for 26.50 delivered, but the manufacturer doesn't have a 6mm for 2013 and later.
  9. #34
    Mar 2019
    NEBRASKA
    I have speedbleeders on the 2012 RTL...however not on the VSS/ABS....I don't have BUDS....I'm good with about a 90% fluid exchange. The BUDS can measure hydraulic pressure as well as other factors-I've been corrected by purists on this matter that it is important since afterall ya need to stop and other systems are tied into this algorithm-but we all get to make our own decisions -some good some bad. I'm happy for the most part. I'm not happy in comparing my 2014 RTS Brembo brakes vs my 2012 RTL brakes....the early brakes in comparison are poor. I know both Lamonster and BAJARON support the idea that changing rotors and pads on the pre brembo SPYDERS brakes can help increase functionality. Well-I don't think they could possibly get any worse so there's that thought.
    2012 RTL 14 RTS , Pearl White @ Pearl White
  10. #35
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by davev1pa View Post
    I assume that both yourself as well as Motorsicle realize that this is a 2 year old thread? just sayin.....
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  11. #36
    Jan 2019
    Kentucky
    speedbleeder.com has a chart on the web site.
  12. #37
    IMHO I doubt there is 10% of the brake fluid for the ABS portion of the system .... good luck .... Mike
  13. #38
    Oct 2021
    Wichita, KS
    I've used this https://www.motionpro.com/product/08-0143 from Motion Pro for years and it works excellent.
    Peter Pan has struck again!
  14. #39
    Quote Originally Posted by FrogmanDave View Post
    There are a number of aids that make the bleeding process easier. But this won't get the ABS module bled. I am in the camp that it's not necessary. The amount of fluid in the ABS unit is relatively small. And the system is not static. The fluid gets moved around. So, changing it ever 2 years or so is going to keep the system more than clean enough.
  15. #40
    Jun 2015
    Hampton Roads, VA
    Haven't bled the ABS on 1330 yet, but on the 998's I used a 1/4 drive socket with about 12" extension with a 1/2" socket. Took off tupperware on left side, lowered the socket down center front of the engine. Was able to put one eye on the bleeder and got socket on the bleeder. Cracked it open, made a mess (pump pedal tighten method), but all brake codes went away and pedal became rock solid. This was on a 2008GS, probably minute air builds up over many bleeds and pad changes IMHO.
    Also to be fair not messing with ABS bleeding unless pedal is squishy with a fresh three wheel bleed. I change out fluid by pulling thru 3 wheel's bleeders until all fluid replaced.
  16. #41
    All I know for sure is when I bled my brakes using BUDS very little fluid came out from the ABS unit. Probably not more than a teaspoon.
