Shock
When riding alone do people ride on the soft setting or the hard setting. When riding 2 up the soft setting or the hard setting. Me and my wife often ride 2 up so i was just wondering. Thanks.
2015 RT Limited
I leave my air bag on hardest setting all the time.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
No adjustment on my 2018 RTL ,but i find it rides very good ( better than my 05 goldwing i traded in ).
SpyderLovers Sponsor
It seems that most people do not make many adjustments to their suspension. I think that is why BRP and other manufacturers are going to computer controlled adjustments.
These suspension adjustments are designed to compensate for loading, and to a lesser degree, handling. So when you are riding 2-up you would want to use a stiffer setting. When riding 1-up and lightly loaded, you'd want to use the softer setting.
Add to this, if you are doing mostly interstate riding a relatively softer setting might be good. When riding mountain twisty roads, a relatively stiffer setting might do you better.
Try it out....
best way to know is to try it out. Ryde on soft setting alone then with the wife and the try both on the hard setting. I also leave it set on the lower side of hard....so above middle...
2012 RS sm5
I pretty much leave ours at the "75%" setting alone and 2 up. Once in a while I'll bump it up to full when 2 up...It's your ride, play around til ya find the sweet spot for your style of riding. That's why it's there...
2021 RT Limited
Headlights?
I leave near low one up, as you can see the headlights change vertically at night with different settings. Riding two up the headlights went up a bit and I was getting several cars flashing me. Went to one below max to bring them back down. I think if the headlights are aiming right, you are good; not so much ride quality. That may be why this feature is gone on the 2018's, they figured out how to keep it level with computers an sensors(?) - just more things to go awry?
I like mine on the softer side for both interstate and twisties. I usually ride set at the second from bottom setting. Loaded up, I bump it one more and if wifey climbs on I go to the maximum. I have never had a bottoming out problem
Semper Fi
I kept it at the middle setting since I got it, which hasn't been too long. Last Saturday I was out 2up with the wife and bumped it up one. Didn't feel too different. Next time I will bump it up one more and see how it is.
Good advice!
When riding solo on my RSS; I always used position 2 (of 5) on the rear shock. When riding two up, I dialed the shock pre-load up to position 4; which gave me ride and handling/steering quality very similar (if not the same) to riding solo.
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
