2018 RT LTD Handling Question
Are riders still upgrading their 2018 RT LTDs standard swaybars to a heavy version as was the case in earlier RT models to improve handling?
Thanks,
Gerard
First thing I did along with an alignment. The problem with the heim links back when there was a problem with the #4'S, I had a #4 but with no blue dot. Not sure if the blue dot were the bad ones or not but I like the comfort of the metal ones.
Yes....
The OEM bar is better and may be fine for many but the change when the BajaRon bar and links are installed is significant...I always recommend you ryde for a while and see if you feel the need to make any change...
2012 RS sm5
