Page 19 of 23 FirstFirst ... 9151617181920212223 LastLast
Results 451 to 475 of 559
Thread: ECU Flash
  1. #451
    Feb 2020
    Glendale Arizona
    I got an answer back from Wick-it Performance. They are marginally higher priced than MFI ($35). Factoring in the shipping round trip to MFI, not sure which way I'll go just yet.
    are the flash updates the same between the two? I thought I had seen someplace that they were the same flashes.
    2020 RT Limited , Chaulk White
  2. #452
    Aug 2019
    Stoughton, WI
    Did you factor in international shipping costs/customs paper work/exchange rates/etc , as I believe Monster is in Canada. Lot less hassle shipping stateside..
    2022 RT Sea To Sky
  3. #453
    Feb 2020
    Glendale Arizona
    I agree that staying stateside would be faster and easier. Just curious if both offer the same tunes for the ECU. If so, I'll send it to Wick-It.
  4. #454
    indpls in
    get monsters shipping info follow it no problem be back to you before you know it
  5. #455
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    Quote Originally Posted by DoubleA View Post
    they are the same..go to wick it in Louisiana...keep it in the U.S.
  6. #456
    Apr 2015
    Lodi WI
    Quote Originally Posted by 308gunner View Post
    they are the same..go to wick it in lousiana...keep it in the U.S.
    This is a fact!!! Wick-it opens the ECU, copies and sends the files to Monster fuel who sends back the files to wick-it to install and close up the ECU. To risky mailing to Canada. If it gets stopped in customs because back logs or worst yet, it gets lost?
  7. #457
    May 2019
    Fort Washington, Maryland
    I am seriously thinking about getting this done to my 14 STS but am torn on which setup to get. I am not a racer but need the extra power for riding two up and eventually trailering. From what I gathered so far from both Monster and Wick-It is the following:
    1. Stage 2 gains more torque below 5000 rpm (in fact more torque from 3000-700)
    2. Stage 1 is quieter
    3. Stage 2 adds power over 1 from idle to redline at all throttle positions
    4. They both give better fuel efficiency due more power to cruise or maintain a speed at a lower rpm, which will use less throttle opening (whrn running under 45% throttle)
    5. Stage 2 with the power gains you can shift gears between 4000-5000
    6. Stage 2 is good for riding 2 up
    7. Juicebox and Power Commander not in the same league as Stage 2 but are more comparable to Stage 1
    8. Handheld not available for 998s yet and the cost is $350 plus the maps Stage 1 $350 Stage 2 $500
  8. #458
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Stage 2, Nuff said.
  9. #459
    IMHO, from actual towing ..... I'd get the stage 2 ..... when towing you will be going slower than in normal riding ..... good luck ..... Mike
  10. #460
    Aug 2019
    Stoughton, WI
    "7. Juicebox and Power Commander not in the same league as Stage 2 but are more comparable to Stage 1"
    Actually, Power Vision 3 has more than enough capability to make a tune as well as the Stage 2 Monster. Just not an adequate amount of dyno's around to fully tune a Spyder with a PV3.
    2022 RT Sea To Sky
  11. #461
    Oct 2017
    covina california
    Hey did you ever get around to installing your Dynojet?
  12. #462
    Aug 2019
    Stoughton, WI
    Ha.. Soon
    2022 RT Sea To Sky
  13. #463
    Feb 2020
    Glendale Arizona
    Thanks !
  14. #464
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    not on my bike
    it absolutely HONKS thru the airbox above 4 grand(so addictive)
    standard cat + akra with baffles
    monster stg 1?.............just do it
    russ
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
  15. #465
    Greenville Tx
    My last Spyder had a stage 1 and I loved it. Im waiting now to get my ECU back from Wick-It for a stage 2. Cant wait to see the difference! Will post once Im back up and have a good feel of the difference between stage 1 and Stage 2.
    2017 F3 Limited
  16. #466
    Greenville Tx
    I got mine back and installed yesterday. I went for a ryde and it ran good but not as fast as I expected. Not sure if it needs time to adjust or I need to remove the 1 baffle that is on the front end of my RLS cat delete. I don't really want it any louder.
    2017 F3 Limited
  17. #467
    indpls in
    i have it it mine she runs like a beast
  18. #468
    Greenville Tx
    Second ryde today and it was a world of difference. Its a beast today and will get even better when Ricky removes the baffle probably next week.
    2017 F3 Limited
  19. #469
    Jun 2019
    Deltona FL
    Just a heads up.. monster fuel next month is coming out with a hand programmer so you'll be able to switch between stock tune and the different stages...so you can have a tune under warranty...you need to take your Spyder to the dealer?....remove the tune..when the warranty work is done..hook up the programmer..put the tune back in.. nobody knows your business...go to monsters webpage...it's there.
    Any updates on this yet??
  20. #470
    Northern Kalifornia
    Quote Originally Posted by Spyderman2018 View Post
    Been wondering also. Won't the computer keep a memory of a stage 1 or 2 install if one is done with a handheld and then returned to stock?
  21. #471
    Apr 2015
    Lodi WI
    Quote Originally Posted by AY4B View Post
    It takes about 200 miles to collect enough sensor input to change to new fuel tables. Out of the box it is on the same fuel tables as when you last drove it. I know people say otherwise, but I have tested close to 30 versions of the flash for Monster Fuel.
  22. #472
    indpls in
    i really think i would leave it in
  23. #473
    Greenville Tx
    After my conversation with Ricky, I will follow his advice and remove the baffle. He explained that the noise level does not change much at all. The biggest difference is the change in back pressure. With the stage 2 tune I will gain more power with the unrestricted air flow.
    2017 F3 Limited
  24. #474
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by Doug View Post
    Just a little Survey for those that have had the ECU Flashed on their Spyder. Could you provide how long it is that you have being riding with the upgrade and what your results have being, etc.
    about a year one so from going from stage 1 to stage 2 which is fairly cheap as stage 1 is the big hit.
    Loved stage one and stage 2 is great. Hope to ck it out alot soon in these crazy times. Haven't ridin yet this year
  25. #475
    Aug 2018
    Thousand Islands
    I must be the only one not noticing a difference between stock and Stage 1 and its been a year now, i first thought maybe it was a case of getting my ecu back without the flash but I lost my eco mode and I reved it higher than stock rpm limit so i know it got flashed. I even did a comparison with my cousin who is running stock and he actually pulls ahead all the time, he is 20lbs lighter but still.
