Results 1 to 7 of 7
    Feb 2017
    ST LOUIS MO
    Default popping the clutch
    i have a 2015 F3S manual have anyone ever or can it be done
    I have heard of others shifting a manual without the clutch. Never tried it on my 08 SM5.
    Others will come on with more information.
    Feb 2017
    ST LOUIS MO
    just wanted to know if i can start it that way
    Quote Originally Posted by THE Q View Post
    I am thinking the clutch has to be pulled in before starting--unless you are in neutral.
    Jul 2015
    Dorr, michigan
    I have never seen a manual transmission vehicle that you could not start that way. The clutch having to be pulled in is a through connect for the starter circuit, not for any spark to the engine. I would give it a try.
    2020 RT Limited , Petrol Blue
    Default Ahh...
    we are talking about push starting the manual spyder... Never done it as I have a jump starter I carry with me but if needed I could. Once you get to speed popping the clutch will allow the system to start . Best get more speed and start in 2nd as you may just lock up the rear wheel in 1st...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Theoretically it will work. You'll need enough juice in the battery to get the gauges to go through their boot sequence. And the Spyder doesn't do well on a low battery so that might also be a hurdle even if you can get it to turn over.
    Then you have to deal with the fact that it doesn't take much to break the rear wheel loose. So getting enough traction to turn the engine over may also be problematic.
    Then you will find there is quite a bit of drag on the transmission even though you've got the clutch lever pulled in. Hard to build speed that way.
    I'd try it in 2nd gear if I were going to do it. But frankly. I think you're way ahead to keep the battery charged and crank it with the starter. I certainly would not count on being able to bump start the Spyder.
    Let us know how it goes.
