Results 1 to 10 of 10
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default Going to replace vacuum lines on 2010 RT and I have some questions...
    1. I found that the recommended replacement is Napa part number H466 silicone hose. I assume that this will be the right diameter for my 2010.
    2. See pic below: sorry it is so huge but I needed to see the details.
    3. I read that all I need to do is cut the new hoses to the same length and replace them. Are there any retaining clips on the ends of the hoses?
    I looked at TechSpark manual, BRP site, and searched the forum to get some help. This was the best I could find to help me. I am not an expert wrencher but I like to tackle some of the simpler maintenance jobs. Thanks for your tips.
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by BigGuy66 View Post
    Jim
    No retaining clips on the hoses.
    David
    Sep 2016
    clark county indiana
    Default making the cut
    when cutting the hose make the hoses the same length as the hose you are about too swap out , ( not cut the 2 new hoses same length 2 (6 inch hoses ) just to make clear what the term is " cut the hoses same length "
    Sep 2016
    IMG_20171111_135824.jpg these were the ones I replaced
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Where do you access these hoses? I would like to replace mine also.
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    I don't have a clue either, so here I sit awaiting the wisdom of others.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Nov 2015
    Chardon, OH
    Default Hoses
    Good Morning. Well, you pull the left side upper panels off and look in towards the throttle body. The MAP sensor is the plastic sensor held on by the big silver screw. There's a hose on each side going to the front and rear throttle body. The hose connection on the throttle body end has a barb on it so the hose might be a little stubborn to remove. It should just slide off the sensor. Helps to have small hands to work off the front hose.
    Spec length is 85mm long for both hoses. 3mm ID hose.
    Doug
    ”Freedom is not a loophole”
    Nov 2018
    Altamonte Springs, Fl
    I have a 2011 RT. Can I get to the hoses by just removing that left upper panel and get my hands on them? There are two throttle bodies with one hose on each right? How long are they?
    Oct 2014
    Fort Mill, SC
    If I recall correctly they are 4" each. Just measure the old ones and make the new ones the same. The hose to the rear is easy to remove. The one to the front is a little more difficult.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by dg110270 View Post
    The link below I posted large color pics of the lines. And yes to your question.
    https://www.spyderlovers.com/forums/...t=vacuum+lines
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
