Results 1 to 6 of 6
    Idaho
    Default Question about brake pads
    I was getting ready to throw away the OEM pads I replaced last week when I noticed there is a shim attached to the backside of all six pads. I kind of think they are there for noise suppresion more than anything else. I looked at BajaRon's instruction sheet for the new EBC pads to see if they are mentioned. Either I'm a poor reader or he says nothing about the shims. So, should the shims from the old pads be used with the new pads? It wouldn't be a big job to put them on the front wheels but the back one would be a royal pain! Plus, I already smeared the backside of the pads with Disc Quiet goop.
    2014 Copper RTS
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    The only things you need to transfer to Ron's pads are the small wire clips if there are none on the new pads.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    The backings are used on the new pads to stem brake squeal. Sounds like you used another method to do just that. If it works fine keep riding.
    2016 F3L , Big Bike Parts Black
    Default ANTI SQUEEL PADS
    The last time I changed my rear pads there wasn't enough clearance to get the caliper onto the brake disc ....so I didn't put them on ....I did put a very small amount of anti-squeal paste .....that worked ..... Mike
    Aug 2007
    Greeneville, TN
    The shims are designed to reduce noise. You don't have to use the shims. But if you can get them in, it doesn't hurt. You can still use CRC Brake Quiet which will increase noise reduction.
    Active Member MDBrion's Avatar
    Feb 2016
    Southern Maryland
    Thanks for the information folks, I’ll plan on cleaning up and reusing the bolt. Appreciate everyone’s insight !
    Just cause you got the monkey off your back doesn't
    mean the circus has left town.
    - George Carlin
    Hollywood, Maryland
    2015 F3S, SE-6
    oem backrest, oem saddlebags, F4 Customs windshield, oem fog lights
    2011 RSS, SE-5
    Handlebar Riser, Heat Wraped exhaust, Power ports int./ext., 23" touring windshield, Led brake lighting strips.
    2014 RTL , Black
