Results 1 to 12 of 12
    Batavia NY
    Default Key won't open F3 seat
    The key opens the frunk fine.....nothing when I try the seat! I've tried pushing on it when turning the key but no luck. Any thoughts other than driving to the dealer?
    When this happened on my previous RT & long screwdriver got me to the latch. Any similar way with an F3??
    TIA for your help......
    Spring Park, MN
    Quote Originally Posted by shroth View Post
    Press down and turn the key opposite from when you open the frunk
    Apr 2017
    North Central Florida
    The key opens the frunk fine.....nothing when I try the seat! I've tried pushing on it when turning the key but no luck. .
    Somebody posted the same question a day or so ago......you ??
    Anynow, mine turns to the "seat" position really easily and the seat does not pop up; I need to lift UP on it slightly while turning the key for it to unlatch.
    Jul 2017
    sarasota, fl
    your is an RT and is question is about his F3.
    Seats are different.
    Bryant, Arkansas
    I assume that you are talking about the rear seat (the front seat is bolted down), to remove the rear seat push in and turn your key to the right while gently lifting up the rear seat.
    Cruzr Joe
    Harrington, Australia
    Shroth, Has the seat release ever worked for you, or has it just stopped working?
    HeliBars Handlebars
    Kenda Kanine rear.
    Apr 2015
    Lodi WI
    Default Takes two hands
    When you turn the key to the right you have to lift the right rear corner of the seat while the key turned. When the key is released the seat is still locked. Don't feel bad As it took a couple of tries for me to figure that out.
    Dennis
    Apr 2017
    Quote Originally Posted by ofdave View Post
    Based on subsequent posts from 2 people who are familiar with the F3.......it would appear that the latches might not be much different though.
    Batavia NY
    The seat used to work. I'll give it a go again tomorrow. If nothing works, my 3K service will be soon.
    Thanks for the help that this group is always willing to give!!
    Batavia NY
    Default Got it!!!!!!
    Turning the key with a well timed thump of the fist on the rear seat did the trick.........so thankful it wasn't the cable like it was on my RT
    Ahhhhhhh.....another new seat release technique.... thanks shroth......great to see it’s free.
    HeliBars Handlebars
    Kenda Kanine rear.
    Apr 2013
    Michigan
    Darn! I was just gonna suggest a cement saw, eye protection, and !
    Glad to hear you got it open OK!
