Results 1 to 14 of 14
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default gerbing heating gear
    Where to install gerbing heating plug do you have to go to the battery or is there a closer point to hook it up on a 2017 f3s
    richie spyder
    Nov 2012
    North Las Vegas, NV
    The best place is direct from the battery. You may need an extension wire to get all the way to the right spot. Mine is on the left tube below the body work.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    A better place would be is off the big red lead on the alternator as it connects directly to the battery. Disconnect the battery negative lead first. Add a fused wire connection at the alternator terminal lug. As for ground find a good chassis ground point. If you are putting in a receptacle you can also plug in a battery tender for keeping the battery topped off.
    Default Battery...
    to the battery with an inline fuse is best. route depends on model and battery location and where you want to plug in. I have leads I pull out from under the seat.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2013
    Oro Valley Arizona
    Gerbings recommends the Battery. This is for a good reason. I have had several and burned up the first by not hooking up to the battery
    direct. Needs full and not partial power to operate correctly.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2013
    massapequa ny 11758
    Default gerbing hook up
    ok thank you all for the help
    richie spyder
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    AJ
    Quote Originally Posted by ssmcclub View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Sep 2008
    TX
    Customer circuit under passenger seat. Plenty of current to run the 35 - 40 watts of heated vest or jacket. Already fused at 5 amps (60 watts total power). Been running there since 2015 without issues.
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by pauly1 View Post
    Wayne
    If your running or add Pants and gloves to the jacket this will not work. You use a 15 amp fuse with a dual controller. Do not let anyone talk you out of direct battery hookup. See my previous post. I tried to hook up to something other than the battery and burned up a Jacket while I was riding. Not Fun!
    Jack
    2015 BMW R1200R LC
    Active Member RydeOn's Avatar
    Oct 2014
    Rocklin, CA
    Default Can I Use Battery tender
    I have a 2016 F3T. I am contemplating getting heated vest & gloves, and was wondering if they sell an adapter that I can plug into the battery tender pigtail that is in the frunk to power the gear?
    Spyder Rentals
    www.rydeonmotorsports.com
    Life is a Ryde-Enjoy the Journey
    Currently Own: 2014 RT, 2016 F3-T
    Used to own: 2012 RT & 2009 RS
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by RydeOn View Post
    Yes they do, you may have to change to a higher amp fuse. Check with the manufacturer of your gear.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Mar 2018
    LV
    just want to run heated vest--no gloves or pants--could i just use the circuit under the back seat? why would they have it there if not useable?
    Vermont
    Here is a picture of mine: Newest Spyder farkles 001.jpg.
    It is a" First Gear Heat-troller, with dual controls". The power cord( with the red end) is ran thru the back in the trunk, see picture :Newest Spyder farkles 004.jpg the other end is near the passenger hand grip, that connects to my jacket. When not in use I tuck it out of site.
    The cord that has the red on it, the other end has a adapter on it so I can plug it into the 12v when I use my heated jacket. If I don't use my heated jacket I don't plug it in.
    I secured the "First Gear Heat-troller on my dashboard with Velcro. Also I attaché the strap to my ignition key so it does not fall off.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Mar 2017
    My F3T came with a SAE pigtail off the battery. I increased the fuse to 15 ohms because the wire is hefty enough. I then put an inlet/outlet in the bag spacer where the passenger heated grips control was supposed to go. Pulled the bag and used a 1/4" coaxial connection between the bag and body so that I can unplug it should I ever need to remove the bag again. Drilled one hole in the bodyand hid all the wiring under the seat coming from the battery directly using the BuRP supplied fused SAE plug in the frunk. I merely changed to a 10 amp fuse in the factory pigtail. This is Warm n Safe's outlet module. >DETAILS CLICK ME<
