Results 1 to 17 of 17
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    Default Rear brake closed
    2012 Spyder RT A&C. I'm changing my rear tire myself. Got it off, tire changed and now reinstalling. Go to put the brake housing back and find that the pads are slam shut and have not been able to open them. I have not had this problem when changes the fronts. I know this has been discussed before but I cannot find threads to it. How do I release the piston and open the pads? Need to finish this tonight. Thank you in advance.
    2015 Spyder RT-S Special Edition. Two Brothers Racing exhaust.
    Jul 2011
    Mitchell, Ontario, Canada
    Since yours is a 2012 model. Take off the parking brake lever or pulley and back off the parking brake shaft a turn or 2.
    Default Bummer.....
    If not already done.... release the park brake and disconnect the cable from the caliper to be able to move the lever/wheel back to allow the piston to retract into the caliper. Check your resevoir for brake fluid if to full remove some to allow fluid to flow back as the piston retracts. start by inserting a butter knife and twisting it to start then something sturtier to get it wide enough to fit over the disc...
    May 2016
    No cable connected to the caliper. "be able to move the lever/wheel back to allow the piston to retract into the caliper." What/where if the lever/wheel?
    May 2016
    "back off the parking brake shaft a turn or 2". I don't know what this is. Explain please.
    Feb 2019
    Portland, Oregon
    When removing calipers, place a spacer in between the pads so they won't "collapse." A piece of wood a little thicker than the disc is best.
    Here are the Parking Brake components. Back off the adjuster and you can then remove the cable. You should then be able to wedge open the brake pads. Putting a spacer in between the pads while the caliper is off is a very good idea and will prevent this issue in the future.
    May 2016
    Thank you Ron, and the other replies. 12 hours today on this and now several Maker's Marks, I'm heading to bed. Will resolve this tomorrow.
    Jul 2011
    Remove parking brake pulley. Item 3 in the attached picture. Turn the parking brake shaft enough to allow the caliper piston to be push back into the caliper.
    May 2016
    Everything is reinstalled. Thanks you for the help. Now, I am getting a "Brake Failure" message. What might I have done wrong when reinstalling the brake and putting the Parking Brake pully back together?
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Need to give the brake pedal the "hard push" double click reset
    Others will give you the exact sequence, but it essentially needs to have the brake pedal pushed to reset the pressure switch. I lucked out on resetting a friends after changing out a rear tire, but should be a relatively easy fix....
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Jul 2011
    Check the fault code. Press the mode, set and turn signal cancel buttons all at the same time. If the code is C1282. You turn the key on before pumping the brake pedal a couple times until firm.
    Turn on the key.
    Wait until it fully boots up.
    Stand on the brake pedal.
    Turn the key off.
    Wait a full 30 seconds.
    Release the brake pedal.
    The fault should be gone the next time you turn it on.
    May 2016
    Turn on the key.
    Turn the key off.
    Tried this twice and still receiving the brake failure message. Anything else?
    Houston
    Turn on the bike, do not start. If the brake failure message is still displayed, do this:
    Report back the code and someone here can help you with what nanny is complaining about.
    Did you set and turn off the parking brake a time or two to verify it was working when you reassembled the caliper?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2011
    Did you get the C1282 code???????
    May 2016
    Did get the C1282 code. The last reset attempt paid off. When standing on the brake pedal, it took a long time to hear the 2nd click, then started the 30 sec. count. Don't know if that mattered. Hopefully, the error message won't return. Going to take a ride, check out the new tire (General Altimax 205/60R 15), belt alignment and see if the error message returns. Thank you to everyone who replied. Saved me a trip to the dealer and that cost.
    Jul 2011
    Next time you work on the brakes for anything. Pump the brake pedal a couple times until it is firm before turning on the key.
