Results 1 to 11 of 11
Thread: Coolant
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    Default Coolant
    I just topped up my coolant tank, but I added a little to much just under the HOT line instead of the cold line. Will this cause any problems for me. Do I need to take some out by disconnecting one of the hoses or will it just come out of the overflow line once I drive it.
    2015 RT Limited
    Sep 2017
    INDIANA, USA
    Default Coolant
    I would lower the level using some type of Extractor. My 2.
    ENJOY YOUR LIFE WITH A SPYDER
    Mar 2013
    It will discharge the excess, but you could pull some out using a turkey baser (dollar store) and adding clear hose (hardware store) to the end. Deflate bulb stick hose end into tank and release bulb. This will suck some out, and keep doing that until you are where you want to be.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Default over-fill
    Quote Originally Posted by Rookiespyder View Post
    Due to the difficulty with the cap ( might mis-align it ) which can cause really bad issues , imho I wouldn't bother ..........The oil would be a different story ...... Mike
    Sep 2016
    surfside beach
    Default its haed to see the leval of the coolant i have a 2011 can am spyder rt
    Quote Originally Posted by Little Blue View Post
    my Title says it all help
    Dec 2013
    wisconsin
    I had the same thing happen and I used a turkey baster with a piece of hose stuck on the end. Mac
    Jun 2017
    Hanover Ont Canada
    Quote Originally Posted by Mad Mac View Post
    Thanks for the idea, I used a turkey baster with a straw on the end and taped it together it worked awesome.
    2015 RT Limited
    Mar 2018
    ca
    I can't even see my coolant level
    Any suggestion on how to see the level easier
    I had to stick a wire in it just to make sure there was coolant in it
    And what a pain in the ass putting the cap back on
    Phil
    2010 rs
    Bakersfield ca
    Invalid Emails
    Mar 2012
    Gore,Quebec,Canada
    If you put a flashlight in behind the front wheel and shine it at the back of the coolant tank, you will be able to see the level pretty good.
    2012 RT , stock Lava Bronze
    Dec 2015
    Australia
    Yeah just like netminder's post", thats what I do and then I just rock the Spyder a little so I can see coolant level line
    Regards Peter
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Netminder View Post
    works every time . Thanks Netminder
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
