Coolant
I just topped up my coolant tank, but I added a little to much just under the HOT line instead of the cold line. Will this cause any problems for me. Do I need to take some out by disconnecting one of the hoses or will it just come out of the overflow line once I drive it.
2015 RT Limited
SpyderLovers Ambassador
Coolant
I would lower the level using some type of Extractor. My 2.
ENJOY YOUR LIFE WITH A SPYDER
It will discharge the excess, but you could pull some out using a turkey baser (dollar store) and adding clear hose (hardware store) to the end. Deflate bulb stick hose end into tank and release bulb. This will suck some out, and keep doing that until you are where you want to be.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
over-fill
Due to the difficulty with the cap ( might mis-align it ) which can cause really bad issues , imho I wouldn't bother ..........The oil would be a different story ...... Mike
its haed to see the leval of the coolant i have a 2011 can am spyder rt
my Title says it all help
I had the same thing happen and I used a turkey baster with a piece of hose stuck on the end. Mac
Thanks for the idea, I used a turkey baster with a straw on the end and taped it together it worked awesome.
2015 RT Limited
I can't even see my coolant level
Any suggestion on how to see the level easier
I had to stick a wire in it just to make sure there was coolant in it
And what a pain in the ass putting the cap back on
Phil
2010 rs
Bakersfield ca
If you put a flashlight in behind the front wheel and shine it at the back of the coolant tank, you will be able to see the level pretty good.
Yeah just like netminder's post", thats what I do and then I just rock the Spyder a little so I can see coolant level line
Regards Peter
works every time . Thanks Netminder
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
