Results 1 to 8 of 8
    Jan 2018
    Tennessee
    Default Spark plug question?
    What kind of spark plugs works best on a 2011 RT If you change them myself or is it better to just let the dealer change them at the next service? I've heard that the middle one is a bear to replace.
    Invalid Emails
    Oct 2015
    morgantown west virginia
    yeah, you ain't getting to the front one unless the airbox is removed. change the wires also . bajaron has a kit that can't be beat.
    Mar 2013
    Oz
    Just make certain the leads are replaced at the same time. Essential.
    we have had success with bajaron plugs and leads.
    Jan 2018
    Tennessee
    Ok thanks to all. I'll check into it.
    Default Well....
    I would go with the tritium plugs and high tension wires..BajaRon can fix you up. On 2011 the front cylinder is a chore...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2018
    Tennessee
    Sounds good thanks.
    Aug 2012
    Central Coast, CA
    Iridium tipped. As stated, BajaRon is the hot ticket with the new wires and plugs.
    2020 RTL SE6
    Throw another vote on the pile for BajaRon!
    Get plugs AND wires from him...
