Magic Mirrors installed
Got my magic mirror kit today from Lamonster, and installed them in about 15 min. I got the kit with the 4 magnets. When they tell you the magnets are dangerous, believe them. I took one off and laid it on my work bench about a foot from the others, and it took off and made it's home with the others. If they stick together without the washer, they are a bugger to get apart. Seems like a great system though. Thanks.
2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
Believe me, they are great. My dealer absolutely loved them, so much so that he ordered a set for his Spyder.
put mine on the other day.. used the 6 magnet set.. i did elimnate the large washer on the lower front to give a tighter fit to the cowl
JIM EVANS
2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
Awesome! Congratulations!
I plan on doing this soon on my Spyder. If you don't mind me asking, why did you make the decision to buy the four magnet set instead of the six magnet set? I know the difference between the two but I'm hoping you, and others, will chime in and tell me why they made the decision they made so that I can make mine. The four magnet set, like yours, is how I'm leaning.
2017 Can-Am Spyder RT
I have the six set too. Love em. I think those that chose the 4 set opted to because of some savings, and maybe just prefer to still have the mirror hang on the top OEM pin.
2021 RT Limited
Did you put a tether on the mirror? I am considering these but am concerned about them falling off is someone leans on it or something hits the mirror while riding.
thx......brian
2016 RT Limited SE6
Originally Posted by imfleck
Awesome! Congratulations! I plan on doing this soon on my Spyder. If you don't mind me asking, why did you make the decision to buy the four magnet set instead of the six magnet set? I know the difference between the two but I'm hoping you, and others, will chime in and tell me why they made the decision they made so that I can make mine. The four magnet set, like yours, is how I'm leaning.
I got the 4-magnet set also. The top fastener works fine (just lifts off, doesn't need any force), so just replaced the bottom two. Great idea if you do a lot of work on the bike.
2014 RTL Platinum
thx......brian
I don't have the tether on mine. Couldn't figure out how to attach it to the mirror end (the instructions are confusing and don't relate to the parts that come with it). Haven't had any reason to believe tether is needed. Have ridden over 5,000 miles since installing them.
2014 RTL Platinum
thx......brian
I have the magic mirrors on mine ,but the tether is a little short so all I did was run a zip tie between the two wires at each end of the plug and it holds very good.
2015 RT Limited
I did the 6 magnet set, and tether free, Just over 8000 miles on some pretty rough roads, attended at least 3 rallye's with lots of folks checking out all the bikes and have never had an accidental removal.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
6 mags
I did the six mag kit with tether. A great mod.
Mirror Magnets - Tether
I made my own ..... and I just started a Thread " Mirror tether - How to "............Mike
Mirror Removal?
How difficult is it to remove the mirrors with the 6 magnets when you are planning to do some bike maintenance?
Thanks in advance.
~Sandee~
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
WAAAAYYYY Easier than the original system. Just decide which corner to start with I usually start with the outside tip of the mirror housing and give it a firm solid push with my other hand "catching", then just peel it away from the remaining magnets, not much different than the "original" method.
Safe Rides,
IBA 70020 |
found out hard way
you telling me!!!!! got the 4 kit too. until went to show my wife. I said look at this, held them apart so they would smack together. SOO fast that they smacked and broke. waa, waa, waa......had to buy 2 more
Magic Mirror Mounts
I had an early set of Magic Mirror Mounts that I ordered back in January of 2017 directly from Russell Culley in Australia for like $75 plus shipping. Back then the kit from Russell came with six magnets and a tether that wasn't very robust. But tethers aren't really needed anyway as the mirrors will not fall off while riding.
But after my neighbor leaned on one and knocked it loose, I went back with the OEM pin at the top and just two magnets at the lower locations. That was about 15K miles ago and no problems. By far one of the best mod investments I've ever made to my '12 RT-S.
Now using that top pin does make it a bit more difficult to get the mirrors off and back on, but still way better than the original BRP system. And if someone does lean on a mirror, they can't knock it off.
But I was never able to flip and/or move the magnets around such that my analog temperature gauge would read properly. So I'm using the digital bar graph readouts on the cluster. But I do miss just being able to glance at that red needle on the temp gauge and tell if it was pointing at or near the 3:00 position.
Mike in KY
