Results 1 to 24 of 24
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    Default Gold Plugs - are the torque specs the same as OEM?
    Hello,is the Tork specs the same with the Gold Plugs as it is with the OEM. Thanks.
    2015 RT Limited
    Default No
    Gold plugs are hex head . No need for Torx or Allen wrenches...
    ​2012 RS sm5
    Jun 2017
    Hanover Ont Canada
    I mean for tightening them 15 ft pounds or etc
    2015 RT Limited
    Aug 2013
    SF Bay Area
    Never thought the different drive type would affect the torque specs.
    2021 F3 Ltd , Magna Red
    Default Gold Plug
    I'm 99.999% sure it doesn't ..... different bolt sizes may have different Torque specs, the head type rarely makes the difference...the GRADE of the metal does ... Of course the Torque specs for a slotted head is normally less than say a phillips style , and definitely different from an internal or external Hex ....... For Oil plugs I don't even torque them, if there is a leak I will tighten it a Hair more ..... make sure the contact area is absolutely clean, debris can get under that washer and ruin the seal ............... Mike
    The torque spec. remains the same.
    You have to remember that you're still putting it into the same aluminum block as before.
    Sep 2016
    Chillicothe, Oh.
    Exactly.
    2015 RT , Black
    Greenville Tx
    Another thing to consider is the Gold plugs use different crush washers and you need to change them every time and order them from Gold plug.
    2017 F3 Limited
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by AY4B View Post
    Any auto parts store like Auto Zone will have the crush washers
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Sep 2013
    Houston
    If you order your oil change kits from BajaRon, he includes the crush washers and new o-rings for the plugs and filters. So does BRP but who would order those?
    That said, we still will not install the gold plug on the engine side because of the o-ring groove above the threads, the drilled hole for the magnet is too close and creates a weak spot in the plug. A bit too tight and its not the threads that give, the plug shears off leaving the threaded portion up inside the engine. Its a very expensive tear down to retrieve. Several have snapped off. We stick with the OEM plug for the engine side and if you use the right tool to remove, its not a problem.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2010
    Las Vegas, NV
    Default Dimple
    So do the Dimple plugs do the same? Have you contacted Gold plug? We have put in plenty and not had a failure.
    Joe Meyer
    Default DIMPLE VS. GOLD
    Quote Originally Posted by cptjam View Post
    There was a lot of chatter about the Dimple Brand plugs having the breakage issues ..... not the Gold version tho ....... Pics of the broken Dimple was posted, and you could see how thin thread area was from the larger hole needed for their magnet vs. the smaller Gold magnet...... I have a Gold plug ( the engine Torx one ) .....that magnet was very, very magnetic ..... I'm sure it will do the job ....... Mike
    Sep 2013
    Houston
    They both have the same design defect. There were many of the Dimple plugs that failed. They both need to get rid of the magnet in the engine side plug.
    Both Gold and Dimple maintain that any failures are the fault of the owner over tightening. IE head in the sand routine. Will not install or reinstall them, just far too much liability. When one comes in the shop, will attempt to remove after advising owner of problem with plug and replace with new OEM plug.
    May 2009
    Connecticut
    With my 2015 F3 I use the Plugs that came with the bike and Just Tighten them as per the manual. No need to jump threw hoops and spend extra $$$ on Other plugs.
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member sKiZo's Avatar
    Mar 2021
    Michigan
    Are the stock plugs magnetic? You might be surprised how much metal one can pick up on some machines, especially during break in.
    Apr 2019
    PA
    Yes stock Oem are magnetic. The head is the main difference. Gold and dimple are a bit harder I believe.
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    So how do the Show Chrome engine & transmission drain plugs from Lamonster Garage compare to Gold Plugs? Do they "break" like I'm hearing the Gold Plugs do? Or is the magnetic thinner making the thread wall thicker?
    Joe
    2023 F3
    Sep 2013
    Houston
    The OEM transmission plug has a magnet. The engine plug does not, solid steel.
    Aug 2017
    Coon Rapids, MN
    Quote Originally Posted by tibadoe View Post
    Following on to Joe’s question......are the washers that come with the Show Chrome plugs from Lamonster special or when a new oil change kit comes with new washers are they OK to use with the Show Chrome plugs?
    Feb 2012
    Spring City,Utah
    I use the ShowChrome plugs for 5 years now and no problem. I also don't feel like I have to tighten them to the nth degree. 15lbs is not that much. I have always used the standard BajaRon washers with no oil leaks. BTW I know this is a losing battle here but the original washers are not crush washers but simple copper washers,as are the replacement washers Ron sends.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jan 2021
    Descanso, CA
    Per this post https://www.spyderlovers.com/forums/...=1#post1563200 I installed the GoldPlugs at stock torque settings using a 1/4" digital torque wrench but will use 15Nm next change.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Sep 2013
    Houston
    The plugs for the 998 don't have the design defect as they do not have the 2 o-rings mid plug. The show chrome plugs for the 998 are fine.
    .... IMHO threaded parts that NEED high torque - you should use a proper torque wrench .... for LOW torque I use a socket and ratchet and after it's hand tight I give the handle a decent TAP and leave it ..... If this is an OIL plug I will put a piece of clean paper under that area and see if it leaks ( usually not ). if it does I will tap it a little harder ...... this method has worked successfully for over 60 years and I have never stripped any threads .... good luck .... Mike
    Jun 2022
    N.E. Fl
    Apparently Gold Plug has folded, the phone is disconnected and e-mails etc... go unanswered. Placed an order and funds were paid...crickets
    2016 F3-T , Blk/Rd
