Results 1 to 18 of 18
    Apr 2015
    Lodi WI
    Default two current service bulletins
    While stopping to discuss getting a QUICK oil change they ran my VIN# for my 2016 F3L and came up with two active service bulletins.
    1. One was related to increasing throttle friction pull???
    2. The other was an inspection of a fuse box for damage related to a cooling fan failure. I was told if I failed that inspection I would not be able to take the bike home until it is fixed.
    I'm not sure if I am relaying this info correctly? I wasn't happy about taking a taxi home is I failed an inspection.
    Does anyone know the facts about these bulletins?
    Dennis
    Jul 2011
    Mitchell, Ontario, Canada
    Did they print off the TSBs for you? If so could you scan and post them.
    2018 F3 LIMITED
    Default Good to know....
    Have seen a post about throttle issue but not the fan failure. Bulletins seldom come to light and just get done quietly... guess too much whoop la and they become recalls... would be nice to find out what needs to done seeing as they can't do it right away...
    ​2012 RS sm5
    Dec 2015
    Oakley Utah
    I remember a thread awhile back that had a link to Can-Am's website where they post bulletins - and where owners can check their own VIN against applicable recalls, etc. Do you remember?
    2014 RTL Platinum
    Jul 2014
    Mint Hill, NC
    The VIN lookup function on the BRP web site is for safety recalls.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2015
    Oakley Utah
    They don't list service bulletins for the general public, then?
    2014 RTL Platinum
    Feb 2017
    Houma, Louisiana
    Default Throttle
    I have a 2016 RT Special Series. I recently visited my dealer for a small issue. When I went to pick up my bike, they told me that my bike had a recall for something to do with the tension on my throttle. They ordered the new throttle, now I have to make an appointment to get it installed. They said about 30 mins. I'm on vacation next week, so I will get it done then, however, I will be going there at lunch today to set up the service. I will ask a few questions about the details of the recall. It may be the same issue you have. I will keep you posted.
    2016 RT-S Special Series
    Spyderpops LED Bumpskid
    LED headlights and fog lights
    Jun 2010
    Las Vegas
    Quote Originally Posted by Bayouboy View Post
    That would also be a Service Bulletin, if it were a recall you would be notified by mail.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2014
    Mint Hill, NC
    No.
    Cognac 2014 RT-S
    Bossier LoUiSiAna
    Seems not, so if you don't visit you dealer
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Hold the bike hostage if it needs work??????
    That is a new one for me.
    Apr 2012
    Northglenn Colorado
    I had heard that the 2016 F3T had a throttle body recall/issue and I told my friend about it since she has that year, make and model. When she checked with the dealer they told her they never heard of any issues
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    I took my 2015 RTS in for a tire change and they have whole list of parts ordered for this throttle issue. I'm not too happy if it makes the twist harder.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Apr 2015
    Lodi WI
    Default no parts on hand
    They said if the inspection shows a problem can-am doesn't want the dealer to release that Spyder until the repair is made. Something about the location of a fuse box or block where road debris can damage it or the wire going to the cooling fan?? Sounds like more than a service bulletin if they can take away your key after an inspection and make you walk home.
    The other is to put more spring tension on the throttle return. I don't want more tension and they made note I declined that service bulletin.
    I'll ask for a print out of the service bulletin
    Jul 2011
    Quote Originally Posted by Tazzel View Post
    Throttle and throttle body are 2 different things. Could it be you got it confused.
    2018 F3 LIMITED
    Nov 2012
    North Las Vegas, NV
    My throttle works fine.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2015
    Lodi WI
    Default Mine too
    I think some attorney stated in court that the reason his client's Spyder ran into the back of the police car wasn't because he was legally drunk, but the accident was caused by a weak throttle return spring. And so starts the service bulletin.
    Feb 2017
    Houma, Louisiana
    The service person told me that the throttle return needed more tension. I have an appointment to have a new throttle installed on Tuesday.
