Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Active Member spydernatic's Avatar
    Aug 2012
    Covington Georgia USA
    Default First service on 2017 RT
    I was at my local dealer on Friday and decided to go to the service department to inquire about the cost of my first 3000 mile service on my 2017 RT He quoted me $480.00 but then said he can do it for $400.00 Is this the general price that is been paid for a 3000 mile first service??
    2017 RT Limited
    2017 RT Limited , White
    Aug 2013
    Northern California
    That is a fair price!
    Default Depends...
    It does vary from one dealer to the next. If you have some dealers that you could call and see their prices it would be worth the time. It is in the ball park for a full first service. Some have done the oil and filter them selves and saved...
    ​2012 RS sm5
    It all depends on what their hourly rate is...
    My dealer charges about $200, but his hourly rate is only $65.00
    Jul 2014
    Mint Hill, NC
    My 3,000 mi service in Jan 2015 was $255.39. Where's the dealer hiding the gun? Annual inflation is nowhere near 19%, even in GA.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Bryant, Arkansas
    Generally better to allow the dealer to do the first service so they can check other things.
    Slightly higher than most dealers by about 12%
    Cruzr Joe
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by spydernatic View Post
    I can not see what they could possibly do that would cost $480.00 dollars. We don't have a dealer in my area I would ever consider going to. I would just have to do it myself.
    2021 RT Limited
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Default FIRST SERVICE
    The dealer where I bought my RT did my complete service for $200.00, that was In southern Ohio..
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Apr 2012
    Northglenn Colorado
    I just got my 2017 F3T serviced for its 3k. It cost 235.00. I dealer about 20 min away cost 480.00 for the same thing. Shop around, prices vary.
    Oct 2016
    Faribault, MN
    I think a 2017's 3000 mile first service is a lot different than a '13's first service though. I don't have my service schedule available for newer than '13's but its a different set of tasks and checks on the newer 3 cylinder 1330's.
    I'm sure someone with a newer model could pipe in with the differences.
    Our 13's were the last of the vtwin RTL's weren't they?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    My dealer charges $130 per hour for labor. Most oil change/check out services cost me about $325 or so. Your dealer is a bit high compared to many posted by others.
    The upside: The next oil change is 9,500 miles later or once a year--whichever comes first. Valve checks are no longer required.
    I would recommend having the dealer do that first service.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    That's close to what I was told by my local dealer. I also had state inspection and a laser alignment added on.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Aug 2012
    Thanks for all the input to my question I do believe another dealer quoted me $318.77 parts and labor included and $195.97 for just an oil change on the 1st of Feb. this year I actually put that info in my phone and forgot about it when I asked the young service advisor of my local dealer for a quote on Friday. I checked my phone today and found the note. The local dealer quoted me $480 and then dropped it to $400. I think their hourly rate is around $130.
    Anyway I will be phoning around before the service is due and with this info on my phone I will go back to the local dealer and show them the info I have to see what they have to say and try and see if they would match the $318 or at least get a bit closer.
    2017 RT Limited
    Jun 2015
    NYC
    lol lol that crazy
    Member shiney side up's Avatar
    Jan 2013
    San Francisco Bay Area
    Default $250 for oil change
    I am looking at buying a Spyder when I sell my Victory Vision this spring. I asked the local Spyder dealer what they charge for an oil change - he said $250 said it was about a 2 hour job.
    I called another Spyder dealer 90 minutes away and they also said its a 2 hour job.
    I've watched videos on YT and it does not appear to be a 2 hour job.
    I wonder where that road goes?
    Ness Custom Tour Victory Vision. (for sale)
    V Strom DL 1000
    Oct 2016
    Faribault, MN
    Shiney, The first time I did it myself, it seemed longer, but I can change Oil and both filters in less than an hour including cleanup. But that is on a V-Twin 998 that's been moded to allow easier faster changes.
    Safe Rides,
    IBA 70020
    Apr 2017
    North Central Florida
    Just got off the phone with a dealer about 50 miles away, which is about as close as any dealer with a good reputation, and they estimated $300 for "first service"; about 2 hours he said.
    Gonna have them do an alignment too. Forgot to ask what that will cost.
    Nov 2013
    Oro Valley Arizona
    Well all first services are not the same depending on the shop. Get a list of all the things they do and
    make sure they all get done. Some mechanics cut corners or are faster than others. Make sure you get
    what your paying for and that they follow all the recommended procedures and checks not just an oil
    change. I would suspect those that are $200 or less.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Sep 2013
    Houston
    Quote Originally Posted by shiney side up View Post
    Its NOT a 2 hour job.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Must be HOJ
    I had my RT's first service done July 2014 in southern Ohio too, Honda of Jackson.
    I asked to watch and was let in. All that was done was an oil change, checked the torque
    on the wheels and checked the lights. I'm thinking it was about $145.
    I"ve bought new bikes before but never have had a first service done. But I spent $31 large
    on this one and wanted it on record the first was done where I bought it.
    Chuck
    Quote Originally Posted by STELLING MAN View Post
    Jun 2015
    Zanesville Ohio
    Default 2 hours?
    When I started doing my own oil changes it did take about 2 hours. About 45 minutes now.
    I jack my '14 RT-S up, use 2 oil pans and drain the oil. Then I get up and take all the tupperware
    off to change the filter. This takes the most time. After that's done I replace the drain plugs and refill.
    Start up and check for leaks then put it all back together. I've done it so many times I have a routine.
    Chuck
    I suspect that most dealers use a shop "rate" book for each job. It has most jobs pegged by x hours of labor. They use that mostly unless they run "overtime," then I am guessing they hit you for more. No dealer does "actual" time any more. Car dealers do the same all the time.
    Active Member Border Rider's Avatar
    Aug 2015
    Derby Line Vermont
    Default First Service
    Bottom line, your dealer is a crook. if he really wanted to sell and service Spyders he would be more reasonable.
    My 3000 mi check was under $100.
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Border Rider View Post
    Now we know! Everyone stay away from your dealers. Their all crooks. Move to Vermont! 😁
    Jack
    2015 BMW R1200R LC
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Cool I did my own first oil change.
    Maybe I’m being unwise (stupid) here but I read prior to making my decision about this that the first service is basically an oil change and just checking wheel lug torque and then basically looking the machine over for anything that looks like it needs to be addressed..! I talked to the service advisor at the dealership and was told to keep a log of my oil changes and the receipt of the oil change kit that I purchased from them and I would not do anything to hurt the warranty on it. Took me about 1.5 hour to complete this. Maybe I’m missing something here but I have been wrenching on bikes my entire life and think I should hopefully know what things to look at. And by doing this myself saved myself a lot of $$.
    Flame away ...
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
