Results 1 to 4 of 4
    Member AlfredENewman's Avatar
    Feb 2016
    Minnesota
    Default Painting an RT-622 trailer
    Does anyone have an idea what it would cost to have an RT-622 trailer painted to match a 2014 cognac RT-S? Thanks!
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by AlfredENewman View Post
    You might want to look into having it wrapped. It'll probably cost less. Here in Indianapolis it can be wrapped for less than $500.00.
    2020 RT Limited , Chalk
    Mar 2015
    Brockport, NY
    Default Local vocational tech school
    I had mine painted at our local vocational technical school for under $300. They charged me for materials only and I think they did a real nice job and it was a great learning experience for them.
    2014 RT-S Pearl White
    Default PAINTING
    If you use BRP " Cognac " paint it's going to be more expensive than if you buy some VHT Burnt Copper ( SP 402 (?) )..... this stuff is a high heat paint and very durable, it also matches the Cognac, if you clear coat it ... you can't use it on BARE plastic .... you must under-coat first .... ask the painter to see if it will save you money ......Mike
Tags for this Thread
