Results 1 to 18 of 18
    Brooklyn NY
    Default canister pre-filter
    anyone know where i can buy the canister pre filter for a 2014 rt limited
    Nov 2012
    North Las Vegas, NV
    https://www.cheapcycleparts.com/oemparts/a/cam/53f54615f870021dbc21b7ed/fuel-system
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Brooklyn NY
    I was looking on the web site before posting couldnt find it.
    Changing the canister prefilter is one of those PITA jobs that take longer to remove and replace the Tupperware than to change the filter.
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by lewisalice View Post
    It’s under fuel system.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Brooklyn NY
    It says replace at 28k? should i just leave it
    Brooklyn NY
    I am def having a brain fart finding it do you know the part #
    Nov 2012
    North Las Vegas, NV
    709000524
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Brooklyn NY
    709000524
    thanks
    Nov 2012
    North Las Vegas, NV
    thanks
    https://www.cheapcycleparts.com/oemp...ed/fuel-system
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Aug 2012
    Central Coast, CA
    I posted up a how to a while ago, but the long and short of it is, you don't have to replace it. You can separate the two halves and clean it and reinstall it.
    2020 RTL SE6
    Mar 2018
    Madison, WI
    Old thread, I know, but I would like to ask a question of anyone who has taken this filter apart and cleaned it.
    For someone who drives on roads and not often very dusty, how much dust can really accumulate in this filter?
    And since the air goes through the charcoal filter of the EVAP system before it could get to the gas tank, how relevant is this filter at all?
    I don't recall seeing such a redundant filter on any other vehicle I have owned, car or motorcycle.
    2014 RT - SE6 , Black
    Quote Originally Posted by Madison Sully View Post
    I think it's a waste of time to mess with the evap canister unless you need it to pass inspection. Much better to eliminate it altogether. About the same amount of effort. Much less expensive. And permanent.
    Jan 2021
    Descanso, CA
    Smile Pre-canister filter easier to clean than access
    MS -- I took my pre-canister filter apart (two Philips screws), washed the filter in detergent and water, patted it dry with paper towels, and reassembled.
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Will it eliminate the smell of raw fuel after replacing or cleaning evap pre filter
    Jan 2021
    Descanso, CA
    Thumbs down TLI (Too Little Information)
    Do you even own a 1330cc model?
    Personally I think it's the fuel pressure hose from the tank to the fuel filter (the hoses are a bit cheap) and it's about to leak gasoline onto your right leg. Probably won't ignite though.
    Quote Originally Posted by RudyB View Post
    Eliminating the Evap canister will rid you of the smell. Forever! Also eliminates potential PVC valve issues.
