Results 1 to 25 of 29
    Sep 2012
    Louisburg, Kansas
    Default Motobatt bateries vs. Yusa Batteries
    Hello:
    Curious if anyone out there has experience with the MOTOBATT Batteries for the SPYDERS vs. Yusa or what ever STOCK batteries BRP puts in the original equipment.
    I know Lamont likes the MOTOBATT product am thinking even though I leave my battery on a maintainer it is 3 years old now and probably should be proactive and replace it.
    Motobatt Batteries have a 1 year replacement warranty but are expensive $149.00
    Any thoughts would be appreciated! Thank you!
    2015 RT-Limited SE6-TricLED Fender LED's (Red and Amber), 3rd LED Brake Light/Tail Light, ISCI Handbrake with black small hands handle,Spyderpops Rock Guard. ,Can-Am Adjustable Wing Vents, Bumpskid, Bajaron's Sway-Bar with metal Heim Joints. Elkas Stage 2 Plus., TricLED Wide-VU Mirrors, TricLED Jumper Port, Laser Aligned!
    Default MotoBatt batteries
    From what I've heard here a few years ago , they seem to have a checkered reputation ( they are now more expensive than they were )...... I've heard about a few clunkers ...... imho , there isn't a better product than the Yuasa brand ............. Mike
    Default Agree
    I have seen batteries come and go through the 50 odd years of using, recommending and working with YUASA. They are still the better battery. Mine is currently 6 years old and doing well. but not to say others aren't any good...
    Apr 2014
    Beloit Kansas
    three years, is probably pretty good time to think about replacement. Your RT will tell you when.
    Do your lights get brighter when you rev it. Maybe not turn over quite as snappy as usual, especially when cold. Lots of hints...
    Quote Originally Posted by Elembytes View Post
    Hello:
    If you've taken care of it somewhat properly it could be good for another 2 to 3 years. I wouldn't replace it until you start seeing problems, like a severe voltage drop while starting. I'd say get a volt meter and watch the voltage. If you open the throttle all the way you can crank the engine without it starting. Watch the volt meter. If it drops quickly down to just above 10.5 while the starter is cranking the bike your battery is probably approaching its end of life. At 10.5 is when the Spyder won't start.
    As far as brand, in my estimation the OEM battery is the best overall value for the money there is. It's definitely the one item on the Spyder where the OEM replacement is pretty much the best choice. When you start questioning how good your battery is, look online for the best deal and get the bottle fill version. Hang onto it until needed. Don't put the acid in until you need it. Just make sure to set it up for use per instructions.
    Apr 2017
    North Central Florida
    Quote Originally Posted by 4 MARIE View Post
    three years, is probably pretty good time to think about replacement. ..
    Unless you suspect that it has been "abused" at some point, you likely will be throwing away half of it's useful life.
    Then......if you ride at least once a week for half an hour or more, it really is NOT necessary to keep a tender connected all the time.
    If you do, that will ensure that your Y starts every time in the safety of your own garage.......and will also likely ensure that when it does fail it will happen out on the road somewhere.
    Just watch for the "signs" and replace as necessary.
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    I never really thought of it like that, good point!
    2014 ST Limited , Silver Platinum Satin
    Aug 2012
    Central Coast, CA
    I bought a MotoBatt from Lamont about a year ago and it's worked just fine with no issues. The stock battery on my 2014 failed last year, hence the replacement. Lamont does extensive research before he sells a product, and so do I, and the MotoBatt brand has a good reputation which the exception of a few fliers.
    2020 RTL SE6
    Apr 2013
    Rocanville Saskatchewan canada
    My riding friend had an off brand battery that lasted three years. I have yuasa batterys in my snowmobiles, which take the identical size as the spyder battery, and have been in there eleven years. Do not recommend that to anyone but just stating a fact.
    Roger
    wisconsin
    OEM for sure. Yuasa has plenty of motorcycle experience. Mac
    INDIANA, USA
    Default Battery
    All Very Good Tips.During the Ryde Season I do not use my battery Tender, because as others have stated The Battery will tell when it is tired and ready to be replaced. A slow or no crank at the house is a safer way to tell.
    ENJOY YOUR LIFE WITH A SPYDER
    Apr 2017
    Quote Originally Posted by GearHd View Post
    Experience is the best teacher.
    Often those who know the most are the ones who have made the most mistakes !!!
    I'm gonna continue to dance with the girl that came with me to the Prom: Yuasa!
    I've never had trouble with any of my Yuasa batteries.
    Aug 2012
    CO
    The Yuasa in our GS lasted at least 5 years during our ownership.
    JLohPhotos
    2008 GS , Millennium Yellow
    Mar 2015
    forrest above Reno, Nv
    Thumbs up OEM
    I'll go with a Yuasa battery when I replace the OEM. They are good batteries. I did replace the battery in my V-Max with a LiPo battery that weighed nothing( Max's are not light).It's been working great. AND the batt in my 06 Magnum RT is still the original and working fine in the cold weather here at 6,000 ft in the Sierra Nevada.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Default BATTERY
    Is the MotoBatt made In the USA?
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    yuasa has a house brand called Motocross. made in the same factory in Pa.
    beside oem yuasa they are the only ones i ever use. they arent an advertised brand,
    but from my experience ,just as good. just my 2c.
    [joyce & irvin toms]
    Oct 2014
    Southern Ohio
    Default BATTERY
    I guess nobody knows where the MotoBatt Is made, If they are made In China just say so..
    Apr 2012
    Florida
    Quote Originally Posted by STELLING MAN View Post
    Don't think they are made here. Distributor is in Florida. Tom
    2020 Petrol Blue Metallic RTL
    The reason nobody knows is because the company doesn't say where they're made. The US contact is listed on their website as being in FL. One person's name is listed for Distributor Sales, Technical Information, and Operations and Product Development. Gotta be a huge company, right? His address is the warehouse location!
    Here's their customer service contact list.
    The top one is their Main Headquarters. Here's a Google Maps Street View pic of that address. Looks like a real huge manufacturing plant, doesn't it?
    Interestingly, the company that Google shows being there is Carolina Energy Distributors. They are a distributor of several battery brands, including Motbatt. Here's a link. http://www.carolinaenergydist.com. They are a battery distributor only, not a manufacturer. They have a USDOT registration as a private carrier hauling batteries.
    Here's a couple of pics of their Florida address, 2810 Mercury Rd, Jacksonville. The current Google sat view, dated 2018, shows the warehouse being used by Creative Images Embroidery.
    Their contact for all countries outside of North America is in Malaysia.
    Now, consider this, if Motobatt was truly an American company don't you think they would be plastering that info all over their web site? As it is, everything I find about them is totally hush about where the batteries are made. They may not be made in China, but from all indications they sure as h*** ain't made in the US!!
    Houston
    The actual label on the battery says Jacksonville Fla.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member nslowmotion's Avatar
    May 2015
    https://t.me/pump_upp
    Default China
    The MotoBatt is made in China. BUT, so is 3/4 of the parts on your spyder and Mexico as well. Just shipped to and assembled in Canada. If you want things only made in America, we would not be able to afford them.
    May 2015
    Default Florida
    It says "distruibuted by a company in florida, but, made in china
    Oct 2014
    Southern Ohio
    Default BATTERY
    Thanks everybody for the Info, I'm probably going to put a battery In my RT-S this summer, so I'll just stick with a Yuasa, I know they are a great battery, I used them over 40 yrs. In all my Gold Wings..
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Default Battery
    Ck'd online at local batteries plus and got a Delco for my particular model...paid and picked up at store....made in USA
