2015 RTL Center cluster gage blacked out
Anyone run into a blacked out center cluster gage. My went out yesterday while listening to the radio. About 45 minutes into the ride. Lots of static on the electrical systems, radio head sets etc. Got shut down and walked away. Came back turned on the key and the display was back. Did not try any audio checks at this time. 2015 RTL 24k on it. Gas and fuel gages work fine, RPM fine ,Speed fine, all ok.
2015 RT Limited, Baja Ron sway bar, Fred Reese lights, high and brake, comfort heated seat., skid pan, helmet locks, truck light , k&n air filter, fox shocks on frt.
Gremlin¿ glad all came back & working. You don't mention a recent wash or anything that may have fluid wher it does not belong, but just good idea to go ahead & check all your fuses & seals accordingly. See if any codes are present if you can. A casual friendly visit to dealer may provide more insight if you like. (I try to keep friendly with mine, helps keep from digging in my pockets)
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Was the bright sun shining directly on it? I've seen the gauge go dark from sunshine but never while riding, only when parked.
2014 Copper RTS
All of the above....
if any recent work was done good thing to backtrack all the connections etc. The sun and heat is one I have seen and on the early GS/RS you can drop the safty card over the cluster when the sun is to your back...not sure on the other models...
2012 RS sm5
Sunshine !!
Ditto on the sunshine.
Mines blacked out twice when the screen was in constant sun for an hour or so.
My Spyder (same year & model) did that once also. It was never explained and never happened again. Not after a rain or any changes to the bike. I just had to let it go.
Check the battery connections and battery health.
Just because.
