2009 rear brake caliper won't go back in???
How do I get the rear caliper piston to go back in?
You might have to take the parking brake loose and back it out so the piston can go back in. Take a C clamp to put the piston back in. Or sometimes take some screw drivers and wedge between the brake shoes to push it back in. Are you replacing the brake shoes? If so use the old shoes to wedge with screwdrivers so you will not mess up the new shoes.
David
The piston will not simply push back into position. It requires a tool to make it easy or you can try to use a pair of needle nose pliers in the notches to twist it back into position while pushing in on it at the same time. A tool like this makes it a snap as it can do both the twisting and pushing at the same time:
https://www.ebay.com/itm/22pcs-Unive...4383.l4275.c10
You will need to remove the caliper from the bike to gain the access needed to use the tool.
Chuck
This only applies to 2013 and newer. His 2009 can be pushed back with a C Clamp.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
I guess I could have looked up what the caliper actually looked like but the way I read about having to remove the parking brake cable had me thinking it was an incorporated unit...
Chuck
