Results 1 to 25 of 36
    Feb 2018
    ca
    Default 2012 spyder rt just died
    Just got my Spyder 2012 used. First time rider, and absolutely love my bike. Took it out for a short ride today and it just died.. went about three miles from home, stopped at a stop sign and when I acceletated it puttered, didn't have any umph and died. Lights work, radio (iPod) works, has gas. The kill switch was dysfunctional when I got the bike. My husband just replaced the running lights on the fenders with led bulbs, and disconnected the analog gas and temp gauge so I could use the digital gauge on the dash. We saw a video on Youtube that says changing bulbs to led can kill a bike. So he went out and put the old ones back.. bike still won't start, not even a turn over or click. Nothing.
    anyone else have this issue?
    Thank you
    Nov 2015
    Myerstown, Pennsylvania
    How old is the battery? I believe once the voltage gets so low the electronics won't let you do much of anything. Try jumping it. If that works then it's the battery.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Very Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Is it a manual (SM) or automatic (SE).
    If SE, remember, if it died on the road, it's probably in gear, you must hold the brake while starting otherwise, it will no even crank.
    Hope it is as simple as that, if not, then it's above my pay grade.
    2018 RT LTD , Black
    Jun 2010
    Las Vegas
    Definitely check the battery and be sure the connections are tight.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Feb 2018
    ca
    Quote Originally Posted by ottawa-rider View Post
    its an automatic.
    Feb 2018
    ca
    Quote Originally Posted by SteveLaoyster View Post
    ok, we'll give that a try next. thank you
    Nov 2012
    North Las Vegas, NV
    How was the kill switch repaired? Could be that.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2016
    clark county indiana
    Default also 2012 here clutch s-m 5
    quote ---> The kill switch was dysfunctional when I got the bike <-------- a big from the get go ! did you happen to do a test ride before you bought the cycle ? let us know ( what is meant by kill switch was dysfunctional , if you can ) ... some of us , have reaper manual that might be able to help! ------- > try that brake peddle down and try to start 1st though ...
    Faribault, MN
    Turdie12, I hope you've already got this corrected, but, my '13 had a (very Rare) Kill switch failure as well. It turned out that if the mechanic put all of his weight onto that switch it could work, I ended up having the complete right hand throttle assembly / console replaced. Works flawlessly now.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Nov 2015
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    i would check the battery cables for tight .there is also a battery ground under the seat to check plus main fuse and circuit breaker .battery ground under seat is hard to tighten because there is a nut under it thats hard to get at
    Feb 2018
    ca
    currently in the shop. Battery, charging, and kill switch all on the list of to do's for the mechanic.
    Feb 2018
    ca
    hmmmm good thing we got an extended warranty.. this could get ugly. Bike is currently in the shop and the switch is on the list of things to look at.
    Nov 2017
    Tacoma WA
    Quote Originally Posted by Turdie12 View Post
    Good luck on getting it fixed. I would suggest battery as I had a regular motorcycle that kept on dying and that fixed it. But the kill switch not working doesn't sound good either but good luck
    Nov 2015
    What was the prognosis and solution?
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    It could be as simple as the battery. If that is the original battery on the 2012 its a bit past due for a change.
    Feb 2018
    ca
    Default still in shop going on 3 weeks
    it seems the kill switch may be the issue. Couldn't find the correct part or part number, went rounds with BRP saying they needed part number to find if it was a part that was available??? REALLY?? Finally with the help of a salesman at a local dealer 75 miles away, part has been shipped to mechanic. Status as of now not really sure.
    Im hoping this is not a pre-courser to the future of this bike.
    Nov 2017
    San Francisco Bay area
    This is what scares the heck out of me with buying a used bike this expensive. I really hope this story has a happy ending.
    2015 RTL , Yes Pearl White
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default All bikes can break
    Quote Originally Posted by LeftCoast View Post
    What is scaring you?
    All bikes / brands can have malfunctions - new or old.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    INDIANA, USA
    Default Died
    Hope this issue will be FIXED very Soon. Please Keep us Updated.
    ENJOY YOUR LIFE WITH A SPYDER
    Faribault, MN
    Turdie12, After they replaced mine, it's worked flawlessly since. My shop replaced the entire right side console versus just the switch, curious to find out if your shop did replace just the switch.
    Safe Rides,
    IBA 70020
    washington state
    I followed most post who made MODS on their spyders and most and always follows with heads aches. When mods are done,, usually not normal means not tested by BRP. A simple mod of lights will affect minimal amps but more and more mods will. Nanny can only tolerate some mods. This is the big reason WHY I don't do Mods especially electrical. I am a Marine electrician I know.
    2012 Spyder RT SE5 Brake pedal mod
    Nov 2015
    Quote Originally Posted by jerpinoy View Post
    that electrical mods must be done (or not at all) with the thought in mind that they may have to be removed in the future because of problems possibly caused by the mod.
    I installed some nice loud dual horns that I like very much. But when I'm playing music off a flash drive on the USB and I beep the horn, the music gets interrupted. Still working on solving the issue.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Invalid Emails
    Apr 2017
    AZ
    Plenty of used bikes available with existing warranty. This should unscare you.
    Nov 2017
    Yeah definitely looking for that. Without getting into it I don’t come from a riding family so there is limited support for the purchase. If it ends up living in the shop and costing a lot of $$ from the get go it just will make things more complicated. Not complaining about the situation just want to maximize the opportunity for a positive outcome that hopefully the spouse will also want to partake in.
    That being said I don’t want to hijack the thread. I’m pulling for a good resolution for the OP that will be covered by BRP.
