Adjusting fenders
I have a 2012 RT. Put on some new front wheels (General Altamax R43) and they are rubbing the support brackets for the fenders.
I see the support brackets appear to be connected to the axil by 4 bolts each side. When I loosen the bolts, the fnder loosens.
Can I remove those bolts, add a couple of washers too give me added space, without messing up something?
TIGHT FIT - FOR ALTIMAX
I had the same issue, with the same basic style fender, ....but mine was for a 15 inch wheel ........ I did the washer/s route and got the clearance I needed ....... I also shimmed the inside of the fender at the rear by 1/4 inch to prevent rubbing ..... The 175 Altimax is actually a bit taller than most 175's ...... This just proves a point I've made many times ....." Not all manufactures use the exact same measurements " for their molds ...... Mike
Tags for this Thread
