Results 1 to 4 of 4
    Aug 2016
    Beloit, Wi
    Default Help with Bushing
    Any help......2014 Rt. Just move it today to start it.
    Found this on the floor after I push it back to start.
    It came from the floor brake side. I have not had the panels off.
    Thanks3894C9A0-004B-4D34-87FC-9F9846F45EB5.jpgD3C52DC0-28B8-4570-B9D3-B8D3075D4154.jpg
    Thank You
    Mark Light
    Live Long and Ride Hard
    Sep 2016
    Chillicothe, Oh.
    It looks like one of the several grommets that help secure the plastic body panels. Has a dealership had the panels off? It could have been pushed out and been hitching a ride somewhere in the Spyder for a good while. Check to see if one is missing and if there are none missing it may have been riding along ever since the Spyder left the factory. I worked test/quality control at a factory that built large trucks and you would amazed at the stuff I found in or on finished trucks. Half of my fancy tools came to me down the assembly line.
    2015 RT , Black
    May 2017
    Mesa, Arid-Zone-A
    Those rubber grommets are pretty much all the same all over your bike. I bet yours came from the side panel where the fake trox bolts are. The ones down by your knees as you sit on the bike. Pushing the panels on can dislodge the rubber causing them to fall out. And then they finally find a way to the floor eventually
    Semper Fi
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Default Grommet
    A zip tie will keep you from losing them if they are pushed out when installing the tupperware panels.
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
Tags for this Thread
