Results 1 to 5 of 5
    Active Member The Governor's Avatar
    Sep 2014
    Argyle, Texas
    Default 2010 RTS SM5 LOADED $12.5, obo
    bike2.jpgBarnett Clutch
    FOBO TPMS
    BumpSkid
    Grip Puppies
    Infinity speakers (4)
    Blue dash LEDs (Fuel & Temp gauges)
    HID headlights
    HID fog lights
    Frunk interior LEDs
    Fender LEDs
    EBC brake pads, all around
    Frunk switch mod/replacement
    Ducted air, cooling mod
    Pitbull Cat delete
    Insulated exhaust, SS zip ties
    Akrapovic muffler
    Smooth Spyder belt tensioner
    LAMONSTER highway pegs with web footrest
    Denali horn
    Baja Ron’s sway bar and links
    Baja Ron's plug wires/ Iridium Plugs
    Polished clutch lever and reservoir
    Dual custom flag kit
    Comfort seat
    JT air cleaner with custom aluminum splash guard
    Trunk liner
    Front & rear cupholders
    Canisterectomy
    PCV air/oil separator bypass
    Trickle charger and quick disconnect
    44K Miles
    Black powdercoat, powdercoat & more powdercoat!
    Matthew 469-858-8766
    Text or call
    Default Impressive....
    Quite a list of mods and frakles.. should attract some customers even if it doesn't affect the great price... good luck, and where do you go from here...??
    ​2012 RS sm5
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Might be helpful to have some pictures as well as the mileage listed. Good Luck
    2010 RT SE5 , Black
    Sep 2014
    Argyle, Texas
    Default Next chapter.....
    Thank you! Building her has been a pleasure, and could not have happened without THIS SITE! ! I will miss her.
    However.......
    Im looking at a 1965 Shelby Cobra..... Always wanted one!
    1. Check fluids & tire pressures.
    2. Start bike.
    3. Hold on.
    4. Full throttle.
    5. Repeat 3-5.
    Default SHELBY COBRA
    Quote Originally Posted by The Governor View Post
    However.......
    Nice ...... mine is orange with black stripes, small motor but it's pretty quick because of the low weight of the car ....... enjoy .... Mike
