Head light not on when running
Hi all. I have a 2011 RT Ltd and the head light does not come on at all on low beam. The heigh beam an flash works on the left hand side handle bar. How do I get the low beam to work - the manual say it should come on at around 800 rpm : nothing.
All info would be great full. Regards Dave
2011 RT , Manuctaured my own for aux lights Pearl white
HEADLIGHT ISSUE
We in the US have a shutter system for H & L beams ..... I believe yours is a real twin filament bulb,( without the shutter system ) so I would check your fuses because they may have one for H & one for L ....... I think it would be a real co-incidence if both failed at the same time un-less you look to see if they are both on ....... good luck .... Mike
Thanks Mike will have a look. Dave
RT-S PE#0412
I have a 2010 RTS and my left headlight stopped working, so I had both replaced by dealership.
First guess is a disconnected wire.
Second guess. Relay R8 is not fully seated, corroded pin or defective. It is partly working. Just not in the normally closed position.
Thanks all for the info most appreciated. Dave
