Results 1 to 17 of 17
    Active Member 2013REDRTS's Avatar
    May 2016
    Central Indiana
    Default Mirror install help
    I can't seem to get the F-ing mirrors snapped back on. HELP PLEASE
    Invalid Emails
    Oct 2015
    morgantown west virginia
    hook the top, then just "bop" the front and then on the end. this is how I do it.
    Default F-ing mirrors
    Quote Originally Posted by 2013REDRTS View Post
    I'm sure everyone here would like to help ....... however if someone walked up to on the street and asked this question to you, do you think you could answer it based on this amount of info ???? ................... rant over ..... If you are talking about the RT mirrors that have the magnets, do you have three or two magnets ( on each mirror ). Do your mirrors have a safety lanyard ????? .... Did you put the magnets on or did someone else ??? ............ help us help you ..... Mike
    Jul 2010
    Las Vegas, NV
    Default RT mirrors
    Take mirror wire off. Inspect mirror spring fasteners. Spring should be parallel on each side. If not, use needle nose pliers to bend back. Then, a spritz of WD40 on the springs. Connect wire, insert connection in hole. Hang the top of the mirror. Align the prong on the bike with the spring, and using the heel of your hand, smack straight in. Then, align the front spring and prong. Smack. Done. See number below - call if you need to. Joe
    Joe Meyer
    Apr 2017
    North Central Florida
    The top post does not snap, it hooks.
    Hook it on first, then look inside to get the other two mount points lined up and then push down with one hand while giving the outside end a downward "thump" with the other hand. A tiny bit of lube on the bottom posts helps.
    Jul 2015
    Saint Michael, MN
    What helped me have no trouble now going on and off was watching the Shawn Smoak RT oil change video. Two quick slaps and the mirror comes off, two quick slaps and it goes back on. I watched that portion of the video several times and then did it. No trouble since. Watch the video at 11:30. To me, it made a difficult job, very easy.
    Gunner
    Dec 2013
    Check out www.magicmirrors.shop for all the info & to watch all vids on these replacemments for the OE mirror mounts, then talk to Lamonster or Doc Humpreys or any of the other US stockists about getting yourself a set for your Spyder so that you'll NEVER have issues with fitting or removing your mirrors again!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2014
    USA
    A bit of lube helps with the dam clips
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Gunner3773 View Post
    Gunner
    +1 on the Shawn Smoak video on Youtube. If I remember right I think he has one just on taking the mirrors on and off.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    These videos may help
    https://youtu.be/NReoHtqs70Q
    https://youtu.be/28hbblP1HHY
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Oct 2016
    Faribault, MN
    +1 for upgrading the stock mirror clips and springs things with the MagicMirrors, once you switch to them, you'll forget you ever had this issue.
    I originally thought "Now how often will I have to remove and replace the mirrors on my RT?" Way too often to deal with that factory system.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jul 2014
    Mint Hill, NC
    Joe Meyer's description is what Shawn Smoak's video shows. In addition to checking the springs as Joe says I rub them with some fine steel wool to remove any corrosion that has accumulated. I also put a greasy finger dab (barely visible) of white lithium grease on just the ball head of the studs and the mirrors snap right into place as Joe says. I do take the time to clean the studs and springs each time I remove a mirror.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2017
    Mesa, Arid-Zone-A
    After watching Shawn's video, I almost look forward to the next time I need to remove my mirrors...... almost. All kidding aside, really good information here. Next time I remove a mirror I will be certain to check everything and do a little lube job to protect.
    Semper Fi
    May 2016
    Central Indiana
    I think my clip are messed up, going to talk the wife into Magic Mirrors.
    Very Active Member Bensonoid's Avatar
    May 2014
    Benson, NY
    I had one stud that was very hard to get the mirror to snap on to it. I unscrewed it and put a thin washer behind it to bring it out a bit. It snaps on like it should now.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Sep 2017
    INDIANA, USA
    Default Magic Mirrors
    FUNNY, I Just Installed My Magic Mirrors Kit Sunday 1/27/18. No More of the 'Factory SMACK' PS: Purchased from Lamonster's Garage.
    May 2016
    Central Indiana
    Where are you in Indiana Little Blue?
