Limp Mode - Coincidence?
So...I brought my 2017 F3T to have it laser aligned and I added led lights on the front cross bars.
The work was performed by a spyderlovers vendor with a lot of experience. 3 hours later I pay and ryde away.
About 1 mile into the ryde the limp home mode comes on. I went back and he had no idea why.
I'm not blaming him but now I guess it has to be towed to the dealer.
Any ideas out there?
Originally Posted by akspyderman
Keep us informed. I cannot help with a good answer here.
Here are the codes I got
C006C C0063 P0000
Anyone know what these codes are?
SpyderLovers Sponsor
C006C C0063 P0000
lamont should know these. plus I think somewhere on here are the codes
Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
limp mode
C006C C0063 P0000
Have you tried shutting it off, remove the key, walk once around the bike and then restart and ride it. Sometimes things just happen, then as mysteriously as they happen they go away, never to be seen again. Give it a try before you have it towed; what can you loose???
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
[QUOTE=IGETAROUND;1332199]Have you tried shutting it off, remove the key, walk once around the bike and then restart and ride it. Sometimes things just happen, then as mysteriously as they happen they go away, never to be seen again. Give it a try before you have it towed; what can you loose???
Uh...Yeah, didn't work!
Thanks
It is a yaw rate sensor error. Did they reset you on BUDS after the alignment?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
C006C C0063 P0000
Google 'spyder codes' then follow the Lamonster Garage link and it will give you a complete list of codes and their meanings.
You can also download the spydercode app to your phone for more info.
this issue
Everything that happens in the system is logged into the computer and doesn't disappear .... If your Dealer can't find it ..... BRP will help them figure it out ....... BUT they have to ask for the assistance ..... Trust me , it's logged in B.U.D.S. .....Mike
BINGO
2018 F3-T
Originally Posted by IGETAROUND
BINGO
If I remember correctly, when I installed the A arm leds, the speed sensor wire was hanging low enough to rub thru the insulation causing a limp home mode, taped over the bare wire and dealer told me how to reset it, problem solved. That sensor wire is just below the plug and play wire from your A arm led to the fender lead wire approximately 3 inches or so away. May not have been pushed up far enough on the rubber/plastic holder on the fender support. It's located near the end (tire side) of the upper A arm. You'll have to get down and look closely to see it. I had to twist the wire and use a flashlight to actually see the frayed portion. Took about a mile or two ride to clear the code after taping the exposed area.
Reason: additional info
See post # ll . I should have placed it here. Good luck
Did the code come up right after the led install?
I rode about three miles and it came up as soon as the wire covering had rubbed through and went into limp mode. I thought it may have been caused by something I had done during the install and sure enough it was my fault by not taking up the slack when tucking the excess wiring from the fender led that I installed along with the A arm leds. The shop manual I purchased paid off in trouble shooting a possible cause. Check your speed sensor on the inside upper portion of the wheel area, it's held in with one screw. I had to remove mine for more access.
Follow up
So far the nice people at Riva Motorsports in Pompano Beach Fl. ( I'm not being sarcastic ! ) have cleared the codes and aren't
sure what caused them. They realize it could be an intermittent computer issue and are trying to replicate the problem.
I really appreciate Dave and the other guys trying to figure things out for me, very professional...
VERY PROFESSIONAL
