Results 1 to 9 of 9
    May 2016
    Noblesville, Indiana
    Default P1614 could it be fixed?
    Last fall whenever I was starting my 2015 St Limited in cooler temperatures I was getting a check engine light with the code1614. I believe that means throttle body problems. Dealer said I needed throttle body cleaned.
    I Ran 2 tanks of gas with a fairly heavy dose of Techron complete fuel system cleaner and now even with below-freezing temperatures, it starts up with no issue whatsoever.
    Could this have done the trick?
    Default TECHTRON
    ​Over the counter products that claim to do wonders in cleaning or improving performance have been shown thru testing to do little or nothing compared to their claims ....... that being said - the Techron would appear to have solved your issue ....... It's use certainly won't hurt anything ( used correctly )....... However these types of products have been termed " snake oil " for good reason .......... glad it fixed your issue......BRP had several years of serious problems with the Throttle bodies used on the V-twin engine...... the newer ones may be improved versions, I haven't seen the later ones as having issues ........jmho .....Mike
    A good cleaning will never hurt... but it doesn't solve any underlying issues.
    Sep 2017
    INDIANA, USA
    Default Fuel
    Just wondering, What Brand and Type of Fuel are you using. I use Shell Premium or Costco Premium.
    Default Well....
    I have found that though very high tech and all there is a lot of mis-communication between the 7 computers and xxx number of sensors. I call them glitches and they clear many times and never come back. Not to say don't be concerned and check it out and or watch it. Depending on your model and how easy it is to get to the air filter I usually clean the throttle body when checking or cleaning the air cleaner....
    ​2012 RS sm5
    Apr 2017
    North Central Florida
    Quote Originally Posted by SpyderUSA View Post
    Not likely.
    With a fuel injected engine, little to NONE of that cleaner made it's way back up into the throttle body.
    It won't hurt anything to let it go and see if it comes back.
    I think I would have it cleaned at the next service interval.
    P.S. Do NOT fall for the injector cleaning scam. The Techron you used should have done that just fine.......at about 1/10 of what the dealer would have changed you.
    May 2016
    I generally use top-tier premium but it also used Sam's premium. I don't think Sam's is top-tier.
    Idaho
    I don't remember if it's the 1614 fault, or another one, but the BRP solution for the 998 engine is throttle body cleaning. Easy is right. The fuel with the additive doesn't pass through the part of the TB that gets gunked up and needs cleaning. It's not a simple job. The air filter box has to come off. My 2013 RT gave the same code one time. I think my local dealer was able to spray some cleaner through the air intake. The code did not reoccur in the remaining time I owned the Spyder.
    2014 Copper RTS
    Active Member davehirst's Avatar
    Feb 2017
    Christiana PA
    Default Techron
    I have a 2000 Vette, and every once in a while, (About 1 time per season) the gas gauge drops to E, even though there is plenty of gas. I then put in a bottle of Techron, and the problem goes away. I also put some in my Subaru and my GM pickup, and the acceleration improves a lot. Not sure if it's snake oil, but works for me.
    2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
