Page 1 of 3 123 LastLast
Results 1 to 25 of 57
    Dec 2015
    Oakley Utah
    Default Mounting brackets for driving lights higher up.
    I've been looking to add more lighting both to be seen and to see. From everything I know about driving lights, the higher they are mounted, the greater effective distance a given lamp will throw the light. Many on here mount them on the A-arms or fenders, but for my purpose that is too low to the ground. So, I'm going to try mounting them up higher using existing strong attachment points and hopefully avoiding modification of the body panels in any way.
    I decided on the Denali DR2 lights. Got them on sale at Twisted Throttle (they're 2015 models). Great build quality and heavier than I expected. I want to mount them higher than the A-arms and thinking about two locations (see pics). Has anyone used either of these locations and if so, what did you use for a bracket? My metal fabrication skills are practically nonexistent.
    2014 RTL Platinum
    Jun 2010
    Las Vegas
    I’m looking st your picture on my phone and I can’t tell exactly where you’re wanting to mount them but I’d warn you to pick a spot that won’t interfere with panel removal for oil changes.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Ooops...!
    I think you forgot to upload the pictures. You would need a solid mounting place and hard to find the higher you go. Most cars run them above the bumper or on a light bar.
    I see and understand where you are considering mounting. Is the height on your Spyder where you are thinking about mounting going to cause you any problems with oncoming motorists if the lights are bright enough to be assumed by the motorist to be high beam headlights? What does UT motor vehicle law say about placement of such lights?
    Jan 2015
    southern WI
    You could mount them directly to those lower deflectors......the ones that are down and behind the windshield. Just pop a couple holes in each one. Then if it doesn't work out there, those are easily replaced....Just not sure how solid those are mounted though
    2016 RTS , Pearl White
    Dec 2015
    Oakley Utah
    Good question; I don't have the answer. But, judging from all the jacked-up pickup trucks around here with their super-bright driving and fog lights above where I'm going to be mounting them, I don't think that's an issue!
    As far as oncoming drivers go, I will have the ability to turn these off or dim them when I'm in traffic. My big concern is night riding on secondary roads.
    2014 RTL Platinum
    Default HIGH MOUNTED LIGHTS
    Quote Originally Posted by Mazo EMS2 View Post
    ​, but My first thought , since you didn't want to make any holes in the OEM pieces was to make a 24 Ga sheet metal that would go between the side mirror and the body ..... But imho attaching a bracket to the mirror " underside " would work better and the holes would not be noticed if you removed them ...the led's would have to lightweight tho ..... Mike
    Mar 2015
    forrest above Reno, Nv
    Thumbs up KISS principle
    HI Pete,
    A piece of steel strip about 3.5" with 3 holes and 2 spacers about 3/4" dia an 1" long.
    Remove the bolts that hold the wind deflectors below the mirrors and install the strip using the 2 outer holes and spacers.
    Install the light mount bracket in the center hole, run electrical.
    Rinse, Repeat.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2015
    Thumbs up To thin
    Honestly Pete, I think that the pictured metal is thin and will allow the light to vibrate. I would think a minimum of 1/8" steel or 3/16" aluminum would be much better. I think Lowes has the spacers I mentioned, in plastic. They might also have 1" wide strip metal but there has got to be some scrap around.
    I used to have an old pancake griddle ( 1/8" aluminum) that I used for many a project.
    Lew L
    That flat strip is only 1/16th thick, & as such is likely to be too light to hold much in the way of weight, ie, single digit grams, not much more; especially not lights that you really don't want to be vibrating like buggery all the time!!
    Look for 1/8th or thicker strap, if you are going that way; or work out how to triangulate it into a braced bracket!! There again, unless you mount it with those holes all perpendicular to the direction of airflow over them, they are probably going to whistle LOUDLY at one speed or another, & probably all on a slightly different note too! So going for solid & thicker strap is probably a smarter choice.
    Jan 2015
    southern WI
    How about a piece of stainless between the headlight bezel, and the upper panel? Stainless is good and strong, and thin too. The proper bends and it might work to use the upper body panel mounting screw just under the mirror. It would be hard to drill and fab with, but it would be thin and strong to slip under body panels......
    Dec 2015
    Oakley Utah
    I've considered that. Aluminum is too thick for the strength I need and zinc-plated steel would need painting. Is there a source for stainless steel stock that you know of? Home Depot is where I've been shopping so far.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    I'm really ignorant when it comes to metal fabrication. Is this thick enough do you think?
    https://www.metals4uonline.com/stain...metal-304-10ga
    Or, should I be looking at plate rather than sheet metal? That probably is not something I could bend with hand tools...
    https://www.metals4uonline.com/stain...304-2b-3_16ths
    2014 RTL Platinum
    Default METAL BRACKET
    ... OMG, #1....the cost is so over the top ... " ridiculous " doesn't even cover it ----- #2.... at that thickness the light you are mounting could weigh 25lbs. and the bracket wouldn't move ...... I have quite a bit of experience in using / building brackets for various purposes. The bracket only needs to be strong and/or stiff enough to carry the weight of the object. As an example , the stainless steel at .135" is actually twice as thick as the OEM frame that supports the front shocks ( I'm not guessing - I measured it ) which carry the entire weight of the front end of the Spyder .... As long as you aren't sticking the light out from the mounting point ( and you shouldn't if at all possible ) by quite a bit, 20 or 22 ga. galvanized sheet metal would be stronger than necessary .... Home Depot , Lowe's, and even Auto & regular hardware stores have small squares of sheet stock .... If you can't find something in that thickness .....glue two pieces together either after you have made bends or before the glue sets up ......good luck annnnnnnnnnnd Merry Christmas, ..... Mike
    Dec 2015
    Oakley Utah
    Mike, are you referring to the sheet or plate?
    I agree the price is over the top. Where to buy?
    What do you use to 'glue' pieces of sheet metal together?
    2014 RTL Platinum
    Default BRACKET METAL
    YOU - posted a LINK to both !!! ... the SS is " sheet " ...the other is soooo thick it would called " plate " ........... " Where to buy " - re-read my post !!!!!! ............. " glue " their are dozens of types that work with Metal ....read the labels, and pay attention to the DRYING times ................ Mike
    Default SS
    I haven't been able to find stainless steel sheet metal at my local Home Depot or Lowe's, which is why I was asking about sourcing it.
    SS is not normally used for much .... so if you don't have a Metal Yard business in your area ....On-line is probably your only choice .... I have access to a YARD nearby in a City of only 12,000 people !! .... Why do you want to use Stainless, it's pretty brittle, so bending it may be a problem for you ..... Are you concerned about ...RUST .... if so just use a paint for metal - and after it dries to the touch - put the part on a piece of wood and put it your oven at 325* for about 10min ....... this HARD cures the paint, bakes out any AIR moisture from the metal surface, and makes the paint about twice as abrasion resistant.....This also allows you to have your part in any color you want ...... I'm posting this because someone else may benefit from the info ....... annnnnnnnnnnd ....Merry Christmas ....... Mike
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    You won't find any SS at one of the big box stores. Your best bet would be to see if there is a metal fab shop somewhere in the area. I used to own an older Airstream and on several occasions needed parts made that were beyond my journeyman metal skills. They have the machines to cut and bend the metal as well as good supplies of stock material to choose from. The prices I paid were pretty reasonable even considering the cost of materials and my time.
    I would look at mounting it with a bracket that sits under the lower clear air deflector or look at fabbing something that lets it mount to the inner side of the front fenders. If you mount to the fenders then the lights would follow the bends in the road which may be better for dark rural roads.
    2010 RT SE5 , Black
    Feb 2012
    Spring City,Utah
    Give Dallas Thacker in Oakley a call. Tell him Paul DeGrey sent you. Show him what you want and ask him if will make it and how much. If he wont ask him if he has any suitable metal he will sell you.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Durham,Maine
    Do you have tractor supply stores in your area? they have what your looking for
    2012 RTL , Pearl
    A word of caution. If mounting on the A frame bars, don't get wiring to close to the radiators. Installed my lights when the 2014 was new. Two years, and the system had fried. I went to a lighted Bumpskid after that.
    Feb 2012
    Spring City,Utah
    Dallas is my neighbor and plows my drive. Great guy. I'm in Hurricane at this time, unfortunately, or I'd take that suggestion and run with it. How do you know Dallas?
    His wife and my 1st wife were collage roommates at BYU. I have known them since the day they were married. Thais (1st wife) was Janet's Matron of Honor when they were married.
    Small world.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Mar 2015
    Thumbs up I have a simple idea
    Hi Pete,
    If you haven't solved the mounting problem I have a simple idea:
    I'll try to explain-----
    With two spacers extending from the two holes that hold the deflectors under the mirrors ------ a 3 and 1/2 inch pc of aluminum strip with 3 holes. One in the center to mount the lights and 2 more ( one near each end ) ------- mounted to the Spyder with longer bolts in the in original holes.
    I'll be happy to make the spacers ( they are different lengths) AND the mounting plates. I would leave it to you to get the longer bolts and paint.
    Let me know-----
    BTW What kind of lights did you get? LED lights?
    ANNND: Do the new scoops get in the way of the air deflectors ???
    Lew L
    Mar 2015
    My mounting idea will NOT work with the scoops. Might they fit inside the scoop after cutting a hole in the grill???
    Lew L
    Default ADDED LIGHTS
    Lew, the lights are dual intensity driving lights from Twisted Throttle http://www.twistedthrottle.com/denal...8-mount-chrome
    I've attached two new photos showing the area around the mirrors where I'm thinking I'd like to mount the lights. One possibility is the small deflectors directly behind the windshield. The other is below the mirror but as you can see the lower wind deflector has been co-opted by the air scoops.
    it and the mirror bottom... Pete, looking at pic#2, I don't have the scoops so ---- How sturdy are they annnnnnnnnnd are they firmly mounted to the Spyder ??? .... If sturdy - why not attach a piece of flat stock to the top of the scoop between it and the mirror bottom ...... sticking out far enough so the lamp could be attached to that ????? ................. Any thing is possible if you at it long enough ....... Mike
