Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
  1. #26
    Apr 2017
    North Central Florida
    Quote Originally Posted by mikeytheb View Post
    By the way, does anyone know what the factory speakers are?
    Did a quick search through the shop manual (electronic version) and only found the DC resistance: 4 ohms +-
    But that is not necessarily the same as the impedance to audio signals.
  2. #27
    Jan 2017
    Olympia, Washington
    Default mike here
    When the sun shines again can I come visit you to do my '13 RTL? I've got the speakers, even the tools, just not the guts to do this myself....<G>
    I've watched and read all of Bob and Mike's videos and threads as well, have them saved but just don't have the guts to make those cuts....
    I want to applaude you . Im in the same boat, 72 and just dont have the guts to cut in OEM
  3. #28
    Default OEM SPEAKERS
    Speaker impedance mis-match can (but does not always) cause issues. When I do this I will choose speakers of the same impedance as BRP designed (or had some radio company design for them).
    " RSI " .... I have not heard of this company making either speakers or stereo head units ....but that is what's showing on the speakers....... Mike
  4. #29
    Default SPEAKER MODS
    Quote Originally Posted by spider-rider View Post
    The most difficult part of doing this swap is removing the " Tupperware " ..... If you have a Dremel use the most coarse stone after you mark the OEM plastic for a 4 5/8th hole ...... Mike
  5. #30
    Feb 2017
    Ottawa, Canada
    I just finished doing this on my RT. Got the Hogtunes from Fortnine here in Canada for about $250 CDN. Fronts were very easy, but working with the Tupperware in the cold is not the best idea. I was able to slide the front speakers into place without too much disassembly but it required quite a bit of flexing of the dash plastics.
    For the rears, I was fully prepared to dremel the hole for the bigger speakers but then I discovered the speakers themselves were bigger and prevented the plastic cover from fitting back. This required using the dremel to trim the speakers on two sides. Luckily there was enough metal left that it didn’t affect where the cone was glued to the frame. So this is something to beware if anyone else tries this.
    Now I have to wait for spring to hear if it was a worthwhile mod.
    Thanks to you guys for the howto.
  6. #31
    Default larger speaker swap
    Quote Originally Posted by NotSteve View Post
    Interesting about enlarging the rear speaker hole .... the HogTunes speaker bodies must be a bit larger than the JBL 5.25 in ones I used ......What are the ohms listed as ????? .......... Glad you tried the Mod ..........Mike
  7. #32
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Default Speaker upgrade
    The Hogtunes definitely have a bigger frame , I did grind some of the metal frame off.
    Great to see more Spyder lovers trying this mod
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
  8. #33
    Oct 2015
    Iowa
    Default Nice job
    V
    NotSteve,
    glad it worked out for you , thoughts on the upgrade ? Hogtunes is a great company . Sorry should have warned you that a little speaker grinding had to be done
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
  9. #34
    Feb 2017
    Ottawa, Canada
    Quote Originally Posted by Kredab View Post
    V
    NotSteve,
    No update yet, it’s still winter up here so I have at least 2 more months to wait before I can try them. The grinding wasn’t all that bad, but the second one was a lot easier to do.
  10. #35
    Feb 2017
    Ottawa, Canada
    Reporting back after my first spring ride... this is very subjective, and it’s been 4 months since I rode with the OEM speakers, but I’m pretty sure there’s a significant difference. Definitively recommend the front upgrade. For the rear, given the amount of work, i’m not convinced. I have the fader set to center and I can’t specifically hear the rear but they “probably” contribute. I’ll have to try it with the fronts only to hear if there’s a difference. I do think there’s more low range overall.
    I use no-noise earplugs, and i can hear the radio fine even at highway speeds with volume just shy of halfway and speed sensitive volume set to medium.
  11. #36
    Sep 2019
    Stuart, FL
    Did you ever get an answer on what the factory speakers are? I'm wanting to know that too. Thanks
  12. #37
    Quote Originally Posted by Flgman View Post
    ….. see post #28 ….. Mike
  13. #38
    Active Member Northofthesix's Avatar
    Sep 2019
    Leamington, Ontario, Canada
    Crappy... the factory speakers are crappy
    You can't get there from here....
    Mods and Tweaks:
    Showcrome Trunk Rack
    Showcrome LED Trunk Light
    Garmin 390LM
    Spyderzone Floating Hiway Boards
    Spyderzone Mount Dash Bracket
    BajaRon Antisway Bar
    Showcrome full-size brake pedal
    Spyder-2-Go Driver Cup holder
    Ram X phone mount
    SpyderExtras 12 volt Docking Station
    BRP Driver Backrest
    Monster 4K Action Camera
    Spyderzone LED Fender Mount Spotlights
    CASA LED Headlights and Foglights
    2018 RT Limited , Ashphalt Metallic
  14. #39
    Jun 2019
    Texas
    Default Hogtunes speakers
    I recently replaced my wife's speakers with the hogtunes 2 ohm units. They sounded great. After just a couple of days though, the sound is very distorted and sounds like the speakers are already blown. Looks like I'm going to have to try another brand. Suggestions?
  15. #40
    Jul 2022
    Kentucky
    Any video with sound on 🔉
  16. #41
    Checy, before 'replying' to a thread, it ALWAYS pays to look at the date on the first post in the thread; and then check the date on the last few posts at the end too.... roblet58's post immediately before yours is almost 2 years old; the post before that by Northofthesix was put up over a year earlier; and NotSteve's post, only 5 back from yours, hit the board in March 2018.....
