Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: BLEED BRAKES
  1. #26
    Quote Originally Posted by SpyderJerry View Post
    The VCN (Vehicle Control Module) is located to the left of the steering box. There is a full explination in the service manual in the maintenance and chassisi, vehicle stability section...
    Thanks for the location of the VCM information, Jerry. It's a busy piece of equipment.
  2. #27
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    Default Bleeding Brakes
    I am a firm believer in changing out the brake fluid every 2 years and bleeding the brakes is vital to the procedure. Almost all of my motorcycles have had the brake lines changed over to the stainless steel-wrapped lines because, over time, the pressure in those "rubber" OEM lines will stretch/deform and make brakes feel mushy as they stretch under the pressure in the lines. Am I wrong in this??
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
  3. #28
    Sep 2016
    Chillicothe, Oh.
    Nope you're not wrong on that. The rubber lines also have a liner on the inside that can break down with time and old fluid. When this happens the liner can impede the flow of the fluid and can cause all sorts of goofy things to happen. Usually applying the brakes won't be an issue but when you release the brakes the fluid can't retreat because of the blockage and you have brakes not releasing fully. As the rubber lines age they slowly break down and become porous enough to allow moisture into the system. Moisture will cause mushy brakes and if you are riding and braking hard this moisture will heat at a lower temp than brake fluid and then expand and cause goofy things to happen. This is more of a problem on two wheelers at race track speeds and braking, but I have seen it on street bikes with badly neglected brake systems. I was on Deals Gap last year on my old Honda and a guy rolled up on a full dress HD. The bike would barely roll as the brakes were almost locked and VERY hot. I did about all I could do in the parking lot and loosened the bleeders enough to release some pressure and told him to let it cool a bit. Stuff that came out looked like pancake syrup. I asked him when the brake fluid was last changed. He looked at me like I had three eyes, man didn't have a clue what I was talking about. He had big $$$ in chrome and lights plus all the new leather hanging on his back and his first question was "what would that cost me?" "Uh, maybe your life?" All kinds of neat info out there to make your bike go faster, but not so much info on how to make it stop better. I think the two kind of go together don't you?
    2015 RT , Black
  4. #29
    IMO, the best justification for changing brake fluid every two years is because it's hygroscopic. In addition to some of the rubber components breaking down with their constant exposure to brake fluid, who wants water in the system?
  5. #30
    Apr 2011
    GREENVILLE, SC
    Default DONE
    Quote Originally Posted by SPYD3R View Post
    OK, tomorrow i bleed the brake system on my 2015 F3 for the 1st time....I'm of the opinion that the sequence for bleeding is: rear, left front and lastly the right front caliper.... am i correct...?anyone have any additional tips....thanx in advance....Dan PSPYD3R
    OK, so i didn't do it the next day.... sorry...but i did do it today, 2 Jan. 2018....got a vacuum pump kit from HF, which worked excellently.... a new bottle of DOT4 Brake Fluid... half hour of labor (us old guys take longer, since the floor is so far away)... after buttoning up & cleaning up, i saddled up and went for a short ride (in 20F temps) to make sure all was well..... results were a 100% TOTAL success... giddy up.....Dan PSPYD3R
  6. #31
    British Columbia
    Default bleed the VCM?
    curious if you bled the VCM as well?
  7. #32
    Apr 2011
    GREENVILLE, SC
    Default NO
    Quote Originally Posted by lebon View Post
    NO.....
    i purged no less than 20 oz. of fluid thru the system without tapping into the VCM... took her for a ride, and NO CODES or any other ill effects... and i'm here to tell you that the fluid that came out, was as clear as that that went in... yes, i know the old fluid absorbs moisture, but it was still clear....
    Dan P
    SPYD3R
  8. #33
    British Columbia
    Cool, glad it worked out. I want to do my 2013 ST. Have the shop manual to help along the way and when I saw it talking about having to do the VCM and also hook up to the BUDS I got all... oh no! But it sounds like other folk like yourself have done it without much hiccups.
  9. #34
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    NO.....
    Dan P
    SPYD3R
    I bleed my 3 calipers every winter. The fluid has always been clear & just about colorless like the new stuff going in.
    Have never done a complete fluid exchange.
    The Spyder is an '08 GS SM5. I also change out the clutch fluid at the same time & that is always clear & almost colorless as well.
    I wonder what has been going on in the braking & clutch systems of those who report dirty, dark fluid coming out?
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
  10. #35
    Sep 2008
    TX
    I bled the ABS system on my 2016 2-wheeler with a vacuum system as Dan used. There are two discs on the front and one on the back. Bled the longest line first (front left disc), followed by the front right and finished with the rear. Only a moderate discoloration was noted in the brake fluid. The hydraulic clutch was a different story: it was a dark gray color with sediment in the fluid reservoir.
    The brake purge sequence using the BUDS causes the valves to shift which bleeding the system, providing clean fluid to the valves. The manual states:
    1. manual bleed the front left, front right, rear, then manual bleed of the VCM
    2. BUDS bleed the VCM front circuit, then rear circuit
    3. repeat of the sequence in step 1
    4. validate system pressure
    So presumably the open valve position is purge but not the block position or pressure build circuit. But then the calipers don't get bled, do they?
    Wayne
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
  11. #36
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    THANX Jerry.... u da man....
    Dan
    My dealer want's at least 300.00 to bleed the brakes on my 2012 rt. Sounds high to me. My dealer is Honda of Winston Salem N. C.
  12. #37
    Dec 2012
    Murphy, NC
    Default FLUSH BRAKES
    Wow! My dealer in Greenville, SC only charged me $95 to bleed and refill the brake system on my F3-S.
    2020 F3 Ltd
    Spyderpops Bumpskid
  13. #38
    Apr 2015
    Green Bay, WI
    Dan P
    SPYD3R
    There are several pieces of equipment from pressure to vacuum bleeder of you doing this by yourself. If you have a friend that can depress the brake pedal while you open the bleeder valve you will be just fine. Like someone else said..Start from the farthest wheel to the brake master cylinder & work forward--etc. Might be a good idea to completely replace all the brake fluid & eliminate moisture. Same procedure--just make sure the master cylinder doesn't go empty while bleeding. suck the existing dirty fluid out of the master cycl & replace it with new brake fluid before you start the bleeding process---you will notice a color change when the old dirty fluid starts looking clean on each wheel. We never did one on a Spyder but we did a several hundred on all model cars & trucks--it's all the same.
    Darrell
  14. #39
    Active Member Ryan12's Avatar
    Apr 2017
    Wichita, Kansas
    Default Brake bleed
    Does that mean the VCM has a bleeder port? I would think the little fluid that is left would dilute into the fresh new fluid.
  15. #40
    Catonsville, MD
    I've seen one-way valves that attach to the bleeder port on calipers, has anyone tried them??
  16. #41
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by Ryan12 View Post
    In my opinion the VCM brake fluid would dilute into the new fluid. The manual states to start brake bleeding with the front brakes but I'm still in favor of starting with the caliper farthest from the master cylinder. The manual also states there is a bleeder valve on the VCM but unless you have the BUDS equipment I won't worry about bleeding the VCM as long as each caliper's fluid changes from dirty to clear brake fluid. The manual is lacking in directions & info--some parts state using Dot 3 & Some Dot 4. My master brake cylinder cover states use Dot 4. Dot 3 will boil from heavy braking. That has happened to me in my old 24' motorhome coming down a mountain--it's a very unpleasant feeling when the brake pedal goes to the floor & no braking occurs.
    Darrell
  17. #42
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by SpyderConvert View Post
    Brake bleeder valves should be on top of the caliper reservoir--so when its opened the air (lighter than fluid) will escape first under brake pedal pressure. Just make sure you close that valve before the person takes their foot off the brake pedal or else air will get drawn back in when the caliper piston retracts.
    Darrell
  18. #43
    Oct 2015
    Lynden, WA
    Default Bleeder valve
    I used a one way valve for bleeding the brakes on my 2013 ST.
    It worked great and made this a one person job.
    Bought the valve on EBay.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  19. #44
    British Columbia
    Default VCM has a bleeder
    Yes the VCM has a bleeder. It is quite visible and accessible on the top of the VCM. I have used the one way bleeders, Speed Bleeder, they do work good. No need to open/close the bleeder during the pumping procedure. I am finding my brakes still feel mushy after having done a fluid flush. I am not getting any error codes though.
