They will be introduced in early September. The impact on the 18s will be minimal. That hit already happened when you drove it off the lot!
I don't smoke but......
whatever you guys are on I think I want some...
Originally Posted by spydernatic
I think I saw the new motor that will go into the 2020 Spyders it is 1630 4 cyl it will not be supercharged and will not be push out 300 horses but will be in a detuned state at around 130 to 150 horses ...just my opinion ..what do y'all think
The engine in that photo is not for a Spyder. Its turbocharged and there is no way a 1600cc turbo 4cyl is going on a Spyder. Second, it has water cooled exhaust manifold, its a marine engine.
I don't think the F3's could handle anything more than the Stage 2 upgrade. Another 30-40 hp & #torque you'd be spinning thru 1st & 2nd gear, Since it's not the most aerodynamic ride on the planet---cross winds could be a serious issue at over 120 mph--not many ride at that speed--wisely. All my life I always wanted a vehicle with just a little bit more power, then I had the engine rebuilt on Suzuki Hayabusa with turbo. Dyno RWHP was 344hp & #212 of torque with 19 lbs of boost on a 530 lb bike. I changed my mind on wanting more.........................
Might not spin the tire if they'd put a bigger one on there.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
why change something that works just fine??? the 1330 has plenty of power. we just returned from riding in the Rockies with my 2018 RTL with 2 up and had plenty of power to climb those 12,000' mountains..
BIG F
BIG F
The 4 cylinder Mustang also has 'plenty of power' Some still desire a GT500, or Z06, or AMG. BRP also needs a sport version with more than adequate power. These high end versions are very profitable for the companies that build them and there are customers that desire them.
BIG F
have you had anything done to your 1330 ??? i have a 14 RT Limited & my hubby does a cross country ride each year & about to go on another one (august 10th) 2 yrs ago they crossed the rockies at Trail Ridge road & he was two up with our daughter & pulling our RT622 trailer. he said he had to gear down to sometimes 3rd gear just to pull the mountains & the othes on 2 wheels would walk off from them until they leveled out & then he could catch them.
Redneck Diva
Member of the Southern Cruisers Riding Club Chapter #213--Central Georgia Proud PGR rider
