Results 1 to 6 of 6
Thread: CARDO SCALA G9
    Apr 2011
    GREENVILLE, SC
    Default CARDO SCALA G9
    is there anyone out there that uses the CARDO SCALA G9 Head-Set unit.....?
    if so.... do you have a cure for LOW VOLUME....? mine is OK @ FULL volume until i get to about 30 mph... after which the wind noise absolutely drowns out either the music or conversations that are going on...
    i've seen videos of replacing the speakers with larger ones, but i hate to do that... any help would be greatly appreciated...
    PS; Scala reps DO NOT answer my emails when requesting an answer....
    thx in advance...
    Dan P
    SPYD3R
    Default Try this
    You used to be able to go online and update your units. I have the G9's but don't have a volume issue and do have noisey helmets. Use mostly Mp3 player and the intercom. Phone also works great. I have not upgraded but should do it online.... is your source volume up...? if my Mp3 volume is down the scala is not loud....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member rpatsh's Avatar
    Sep 2012
    Spokane, WA
    Quote Originally Posted by SPYD3R View Post
    thx in advance...
    Dan P
    SPYD3R
    Make sure your speaker placement is correct. it they are not right at your ears it is hard to hear.
    2015 F3s White
    BRP Drivers and Passenger backrest
    Blue Ridge windshield
    Corbin Saddle Bags
    Active Member Sccar's Avatar
    Mar 2015
    East Texas
    Make sure you have the latest firmware and check your settings
    2015 F3S SE6
    You don't stop riding because you get old, you get old because you stop riding
    2015 F3s , Orange/black
    Active Member coastrider's Avatar
    Lakewood, NJ
    They have a jack on the bottom for ear buds. Using those instead of the speakers will give you more volume than you need.
    2014 RTS , Spyderpops oversized brake pedal Cognac
    Apr 2011
    GREENVILLE, SC
    Default THX
    THX all....
    i've gone into the software and updated many times... no luck...
    i've made certain my speakers are exactly where they should be... no luck...
    where is the 'jack' for the ear buds...? i don't see one...
    Dan P
    SPYD3R
