good evening all, i am a new member and about to buy my first spyder on which will be a 2018 F3-T or the F3 limited. My question is what type of mounts for your cell phone do you know? I know the 2018 display is digital, has its own GPS on which links to your phone, but i can not get away from my waves app due to all the info it provides. I have always likes the Ram Mounts and this one is what I am looking at:https://www.amazon.com/Mounts-RAM-B-...or+motorcycles
I tried that with my Samsung S7 in a Impact Gel case and ended up switching to a different mount because the "X" arms would always hit buttons on one side or the other, I used the IPOW cell phone mount,
removed it's included base and using some of those RAM mount components and and mounted it over my dash on my RT. You would need a different mount base for an F3 though. But I've rode thousands of miles over very rough roads and never was concerned about how firmly mounted the phone was, and it will fit ANY phone.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020
If I attach these right you'll see how my phone is mounted
Add On’s
2017 Pearl White RTL
SPYDER RAM Multi Mount
Ram Mount Drivers cup holder
Ram Mount passenger Cup Holder
TRICELED Bar/Circle
Brake Light/RGB LED
Ground Effects Lighting
Airhorn/compressor
LED Head Lights
LED Fog Lights
K & N Air filter
Two Brothers SR1
Cat Bypass Pipe
Easter Beaver Accessorie block
USB pwr plug
Removable hitch assembly
I have a X-Grip mount with an iPhone 5SE. So far, I really like it.
I managed to pass my USB cable with all the other wires from the handle and I use the rubber gromet in the glove box to pass it through. So my USB cable is always available to connect to my iPhone and always connected inside the glove box.
I like to keep things simple, I used one of the new pop socket mounts on my F3. Mounted it on the Gas Tank lid. Works like a charm. The problem with phones and GPS's is I can never see the screen in the daylight So they become a little useless.
I highly recommend it. For $9.95, it cannot be beat. It comes with a rubber strap (the red thing in the picture) for extra security, but I don't even use that. Place your phone on it and it stays, and simply pull it off when you need your phone. The magnet is plenty strong enough to hold my phone by itself and have had no issues after almost 2000 miles with it. The magnet has has absolutely no effect my phone.
