Results 1 to 14 of 14
    Nov 2017
    New Braunfels TX
    Default cell phone mounts
    good evening all, i am a new member and about to buy my first spyder on which will be a 2018 F3-T or the F3 limited. My question is what type of mounts for your cell phone do you know? I know the 2018 display is digital, has its own GPS on which links to your phone, but i can not get away from my waves app due to all the info it provides. I have always likes the Ram Mounts and this one is what I am looking at:https://www.amazon.com/Mounts-RAM-B-...or+motorcycles
    Thank you
    Faribault, MN
    I tried that with my Samsung S7 in a Impact Gel case and ended up switching to a different mount because the "X" arms would always hit buttons on one side or the other, I used the IPOW cell phone mount,
    removed it's included base and using some of those RAM mount components and and mounted it over my dash on my RT. You would need a different mount base for an F3 though. But I've rode thousands of miles over very rough roads and never was concerned about how firmly mounted the phone was, and it will fit ANY phone.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jan 2015
    southern WI
    Look for a case/holster that's specific to your phone, and then mount it to a Ram mount. Another alternative is the X-Grip with a Ram mount.
    2016 RTS , Pearl White
    Active Member MSa1956's Avatar
    Mar 2017
    Myrtle Beach, South Carolina
    Default Cell phone mount
    If I attach these right you'll see how my phone is mounted
    Add On’s
    2017 Pearl White RTL
    SPYDER RAM Multi Mount
    Ram Mount Drivers cup holder
    Ram Mount passenger Cup Holder
    TRICELED Bar/Circle
    Brake Light/RGB LED
    Ground Effects Lighting
    Airhorn/compressor
    LED Head Lights
    LED Fog Lights
    K & N Air filter
    Two Brothers SR1
    Cat Bypass Pipe
    Easter Beaver Accessorie block
    USB pwr plug
    Removable hitch assembly
    Jun 2017
    Hackettstown NJ
    Default Lamonster's RAM Mount
    I have the Lamonster RAM X Grip Large for my Samsung. It holds great and doesn't hit the buttons. The phone is just in the right spot for GPS...
    http://www.lamonstergarage.com/lamon...p-with-x-grip/
    http://www.lamonstergarage.com/lamon...-large-x-grip/
    Nov 2017
    New Braunfels TX
    thank you all. this gives me idea on what i am going to do.
    Jul 2011
    Silver Spring, MD
    Quote Originally Posted by teknotaz View Post
    Thank you
    I have the exact same one - install details here - https://ourdiyblogs.wordpress.com/20...r-spyder-f3-t/
    2016 F3T SM6 , Silver
    Active Member MagYukon's Avatar
    Sherbrooke, Qc
    Hi,
    I have a X-Grip mount with an iPhone 5SE. So far, I really like it.
    I managed to pass my USB cable with all the other wires from the handle and I use the rubber gromet in the glove box to pass it through. So my USB cable is always available to connect to my iPhone and always connected inside the glove box.
    X-Grip Ram Mount Phone Holder, Lamonster Fog and driving lights, BRP Heated grip, Home made rear rack + Shad SH58X top case, BRP belt tensioner
    2016 F3T , Red
    Dec 2015
    Oakley Utah
    Quote Originally Posted by PocoToro View Post
    I had one of those on my bike and someone stole the X-grip part off it. I guess they must be popular!
    2014 RTL Platinum
    Active Member Gator37's Avatar
    Jun 2013
    Soap Lake, WA
    Call Cindy at Tricled. She has just what you need. Got one put on my RT at Red Rock. Does a great job and holds phone safely.
    American by Birth, Southern by the Grace of GOD.
    The Older I get the Better I Was.
    Apr 2012
    Northglenn Colorado
    I like to keep things simple, I used one of the new pop socket mounts on my F3. Mounted it on the Gas Tank lid. Works like a charm. The problem with phones and GPS's is I can never see the screen in the daylight So they become a little useless.
    https://www.amazon.com/PopSockets-Mo.../dp/B01DSZQU2K
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Tazzel View Post
    I like to keep things simple, I used one of the new pop socket mounts on my F3. https://www.amazon.com/PopSockets-Mo.../dp/B01DSZQU2K
    Interesting. Didn't know about them previously. Thanks.
    https://www.amazon.com/PopSockets-Ex...A4JZ8F1Z85ERAZ
    2014 RTL Platinum
    Nov 2012
    North Las Vegas, NV
    I found mounting my phone where the sun could hit it directly caused it to overheat and shut down. Works good in the little dash cubby though.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Ashburn, VA
    I have this:
    https://www.amazon.com/dp/B06XZTJ6KL?ref=yo_pop_ma_swf
    I highly recommend it. For $9.95, it cannot be beat. It comes with a rubber strap (the red thing in the picture) for extra security, but I don't even use that. Place your phone on it and it stays, and simply pull it off when you need your phone. The magnet is plenty strong enough to hold my phone by itself and have had no issues after almost 2000 miles with it. The magnet has has absolutely no effect my phone.
    SpyderSkeets
    Ashburn, VA
    2017 F3-T SE6
