Air - escape
I rolled the spyder out of garage, Washed on it, Turned the key on to release the brake. And roled it back in.
Set the brake and - immediately on turning off the key ----- heard a instant Air escape. (sounded the same as
when you release a air pump from a tire) A distinct " Psssst ".
Never did have the engine on. Any ideas ???
Originally Posted by Many brands
I rolled the spyder out of garage, Washed on it, Turned the key on to release the brake. And roled it back in. Set the brake and immediately on turning off the key ----- heard a instant Air escape. (sounded the same as when you release a air pump from a tire) A distinct " Psssst ". Any ideas ???
It would help to know; a) which Spyder you have and b) how long you have had it.
2014 RTL Platinum
Little checking
From your profile I see you have an RTS not sure the year but if you have the air compressor for the suspension it could be that without a load on the spyder at the time it let air out to level the unit.....
2012 RS sm5
P I concur. Bruce
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
re - air escape
Good answer. I do believe you are right. Now I can sleep tonight.
The air compressor only operates if the bike is running and in gear. Sleep tight.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
